Post new topic Reply to topic  [ 31 posts ]
Go to page Previous  1, 2, 3  Next
 Post subject: Re: Gloves!
PostPosted: Sun Oct 18, 2009 6:03 pm
I've been meaning to write a series of blog posts about keeping warm while riding in the winter, and gloves were going to be my first topic. In my experience fingers and toes are the first to feel the bite of winter, and hence gloves and booties are first on my priority list.
As for the "perfect" glove -- I don't think it exists. I have an arsenal of gloves and I use them all. My wife thinks I've gone bonkers with gloves because I have so many, and because anytime we find ourselves in an outdoor shop, I'm checking out the new gloves. Here's a photo of the gloves I use most often. (I actually have more, but I use them for shoveling snow, skiing, etc.)
I generally use long finger gloves when it's 50 degrees (F) or colder. And I'll ride outside if it's 20 degrees or warmer. That's a pretty broad range and there's no way that a single set would cover it for my comfort needs. And because I leave in the early morning, and I generally ride in the mountains, the temperature changes change quite a bit as my altitude changes, and the sun rises. I also need significantly more warmth when descending than while climbing. In addition to the obvious reasons (I'm not working as hard, and I'm going faster, while descending) there's the fact that my fingers are wrapped around my metal brake levers while descending, which can suck the heat right out of your fingers.
I pretty much always choose two sets of gloves for every ride. Sometimes I only end up using one set, and the other set stays in my jersey pocket, but two sets of gloves gives me three options -- set A, set B, or both. And one of my favorite additions to my collection gives me even more options. Notice that the gloves in the upper right are battery heated gloves; they're no silver bullet, by any means, but when the temperature is below 30, I almost always have that set as one of my two. I like to have one set of tighter-fitting gloves, and one set of warmer gloves or mittens, so I can layer.
So until I get around to blogging on the subject, that's my two cents -- start a glove collection; layering is good; and battery heated is a nice option.
www.cyclingtechnology.com
(NOTE: This poster owns a retail business selling weight conscious bike related products.)
PostPosted: Sun Oct 18, 2009 11:59 pm
I just ordered a pair of these :
http://www.pearlizumi.com/product.php?m ... 00&outlet=
After I do a cold and wet ride I'll report back on how they perform.
-John
NCVC
2nd place is just the 1st loser
Friends don't let friends ride clinchers
PostPosted: Mon Oct 19, 2009 6:51 am
:D Your right about the cold tolerance, coming from Wales, and living in Yorksihre for 5 years then Nottingham for 10, i was in shorts and SS Jersy at 15C (all these locations have crappy weather and 1 month long summers). Not hard just didn't know any different.
5 years in Queensland Oz and i am rugged up below 20C, its pathetic. :oops:
I have some gore full finger gloves, but i haven't used since i got here.
I guess based on this you could argue glove selction is unimportant, as if you stick it out long enough you'll get used to being cold......
One thing i did learn, water proof gloves are largely pointless as the rain runs down your arm and fills the gloves from within anyway. Well fitted and windproof generally makes for higher performance.
PostPosted: Mon Oct 19, 2009 7:46 am
The Seal Skinz Ultra Grip glove is just fantastic. Very warm and almost waterproof. You can immerse your hand briefly into water and it will come out dry. They only seem to get wet after many hours in heavy rain.
They aren't cycling specific and therefore there is no palm padding but that suits me as I hate track mitts.
PostPosted: Mon Oct 19, 2009 7:10 pm
being that I see PDX in your moniker and I live/ride/race/commute in the same town, here's what I suggest. Like everyone else here, I have bucket full of gloves to choose from. On those sub 45 degree, rain all day-days that we get from November throuh March. I use Headsweats Glove Covers over wool gloves. You can find them for $10 here http://www.performancebike.com/bikes//P ... 6552_-1___
I buy medium weight wool gloves to wear under them at Andy & Bax army surplus for under $10. Like the Seattle poster wrote, I bring an extra pair in a plastic bag, but rarely need them.
It's the best solution I've found for winter training. Not pro looking, but very effective. I occasionally spray the shells with a can of DWR.
PostPosted: Sat Jan 16, 2010 4:43 am
Yeah I'll bring up this older thread but there was one thing not mentioned which I feel is important and should theoretically apply to everyone. The main reason your extremities get cold is because your body needs more blood to run through the core to keep it warm and limits and the fingers and toes get (feel free to correct that statement but I think it's basically correct.) By keeping your core warmer you need very little on your hand and feet to actually keep them warm.
I do not have any heavy gloves but still ride when the temps dip into -5°C (any colder and well I really do need at least windproof gloves). I wear a wool liner, probably the same thing a previous poster uses which can be purchased fairly cheap, and then assos insulator gloves on top of that. I regulate my body temperature by pulling my balaclava down, or over my mouth and/or nose. So far it has worked very well for me, with only one day this winter when I felt miserable and wished my hands were warmer and it was not the coldest day by a longshot. The only fallback to this system is if you stop for a long (10ish minutes) time and let your heart rate drop your hands will get cold fairly quickly.
Of course I am an oddity who can handle cold better than most in this area and have decent circulation in my extremities when the temperature drops. The above lets me stay comfortable, and still retain nearly all the dexterity I need to do tasks such as shifting, eating and on occasion answering the phone. Like I said I wouldn't mind getting windproof gloves to make the longer rides a bit more comfortable at lower Heart Rates. I've been looking at the assos 851 glove and will probably buy a set when they are on sale in the summer.
My Lynskey R420 with Chorus 11
NEW Developments! If you are interested in a Weight Weenies kit please respond to the thread. I want to make the order happen before long.
PostPosted: Sat Jan 16, 2010 5:48 am
Occasionally in Road Bike Action, I see them wearing Mechanix gloves. Does anyone have any experience with these in cold weather? I am assuming they like them for grip, but I was wondering if the perform as well as some other full finger gloves mentioned.
PostPosted: Sat Jan 16, 2010 5:53 am
I get cold hand pretty easily. I now use ski gloves. You do loose a bit of feel for steering and braking, but surprisingly not as much as you might expect. Look around your house, you might have a pair stuck away somewhere.
PostPosted: Sat Jan 16, 2010 9:16 am
@Arky. I have a pair of the classic Mechanix gloves, which have great grip and are useful when wrenching on my bike. I would not think they have much use as a cold winter glove, though...
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Sat Jan 16, 2010 3:04 pm
LMAO :lol:
More ride reports!! :up:
CoachPotatoBilly wrote:
HammerTime2 wrote:
shadwell wrote:
Assos Spring Summer full finger, great glove. Doesn't get colder than 10C here in Winter, hence the lightweight recommendation.
10C :laughat: :laughat: At 10C, I'm still wearing my summer gloves. Even at 9C when riding CF levers and bar. And another 1 or 2 C below that if already thoroughly warmed up. But to each his own.
****Oh man did I realize people are different with respect to cold tolerance this morning... Our team ride this morning was wet, cold and miserable with temps under 38 degrees F and windy.. Just rain, wind, and cold air. I was wearing neoprene boots, over some long wool socks, with my tights over the boots to keep water from getting in, and I brought my fancy Descente gloves which have long wrist cuffs, are windproof, water resistant, and full fingered with this cover built in to make them into mittens (pretty cool actually!) if you want.. I had a full gore-tex jacket, poly pro tights with knee warmers and a helmet cover. I was ok after warming up but had no need to take anything off as it was just pouring rain and cold..
Anyway, most of us were freezing even with all of this type clothing on. However, one guy who sometimes rides with us was wearing a cheap windbreaker over a regular short sleeve jersey, summer riding shorts, lycra booties, and gardening gloves with flowers on them - just cheap cotton gloves dipped in rubbery goo on one side. He was soaked to the bone and seemingly happy just with what he had on... Just looking at that guy made me cold.
I was really glad to get home and take a hot shower. For all I know the gardening glove guy went ice fishing or something...
brrrr...
PostPosted: Sat Jan 16, 2010 5:10 pm
toutenhoofd and others,
Reviews on battery heated gloves? Warmth, finger dexterity/ability to operate brake levers/shifters, etc.?
Thanks.
PostPosted: Sat Jan 16, 2010 7:55 pm
Down to about 0 deg C in the dry I love DeFeet's Dura gloves. They last forever because there is no stitching to come undone. Even in light rain they work surprisingly well. Lovely and comfortable and slim fitting too.
Adalta Cycling Club
PostPosted: Sun Jan 17, 2010 8:18 am
Man, some of these gloves are really very nice. I never gave gloves much thought, but now I'd like to be a little more toasty in the cold. Nice gloves are a luxury!
PostPosted: Sun Jan 17, 2010 11:40 am
Luxury? More necessity. Without proper gloves I would not be aible to ride in the winter months.
PostPosted: Sun Jan 17, 2010 12:38 pm
They're also cool too!
What I have found is that the textured palm bit folds over itself thus causing rubbing. To solve that, I wear short fingered gloves with a padded palm over the defeet gloves.
Dimples: Laminar flow separates more easily from a surface than turbulent air. Delayed separation reduces drag. A groove perpendicular to the flow triggers laminar to turbulent conversion. A spinning object uses dimples so an edge always faces the flow.
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: No registered users and 12 guests
There are no new unread posts for this topic. Aero Gloves
DCote
Fri Jul 13, 2012 6:41 pm
ms6073 View the latest post
There are no new unread posts for this topic. Giro LX Gloves alternatives
digitalnorbs
Wed Sep 05, 2012 8:13 pm
yeagermeister View the latest post
There are no new unread posts for this topic. good thin/light gloves?
mjduct
15
667
Sat Jun 16, 2012 2:46 am
HammerTime2 View the latest post
There are no new unread posts for this topic. Tired of frozen fingers, best low profile winter gloves?
Bhowe
25
1173
Mon Mar 18, 2013 10:29 pm
Bhowe View the latest post
It is currently Wed May 22, 2013 8:21 am
