sastre
by sastre
[quote="nismosr"]with bad luck on conti comps trying out zipp tangente tubs
:smartass: send them back and go buy some veloflex carbons or vittoria's :thumbup:
Full steam we go against the odds
Headfirst we go against the grain
Against the odds, against the grain
We go against the odds, against the grain
lippythelion
by lippythelion
Kermit, I've got two Climbers Jerseys & really like them. Unfortunately the fabric above the pockets is prone to damage and is easily clicked & pulled by sharp corners on bar and gel wrappers.
emorydptt
by emorydptt
It's a little early in the season, however I am adding another Colnago to the stable.
This will be replacing my Ritchey Breakaway cross bike.
I'm excited to build it up!
Likely with the following since I have parts lying around and they are pretty cheap to replace:
Ultegra 6700 shifters, front derailler, rear derailleur
Brakes: FSA K-Force or TRP EuroX
Cranksset: undecided, but I like the compact ratio
Additional pictures: https://imageshack.com/a/tMeq/1
my YouTube channel- keep the grams down and the watts up!
-2014 Cipollini Bond EPS | 2017 enigma echo SR11 | 2011 Time RXR ULTeam SR11 | 2010 Colnago EPS SR11 | 2013 Colnago C59 SR-EPS | 2011 Colnago Prestige Di2 | 2013 Specialized Shiv TT SWorks SR11
Cuki
by Cuki
So impressed by my white Giro Empires, treated myself to a black pair also. Just need to get some gold laces to match my SuperSix Black Inc. 2014. Really refreshing to lace up like the marathon runner I used to me.
Like djconnel, very pleased with the new POC Octal. Had two back to back 150km rides in Vienna this week where my Garmin 810 was reading 38°c (plus 100°f). Big frigging hills in Austria, so you need lots of ventilation going up and a sturdy lid on your head going down the other side. Mine weighed in at 186gm for a small.
g_doraz
by g_doraz
g_doraz wrote:Specialized s works evade helmet...again....to replace mine that I damaged in a crash. Specialized has a crash replacement program, so I was able to replace the helmet with a 20% discount. A tough way to earn a discount, but I'll take it.
And a pic...
Road bike: Pinarello Dogma 60.1
TT bike: Trek Speed Concept
http://www.youtube.com/watch?v=D4XxCZagAjk
Dodger747
by Dodger747
Intrigued to see how well these work...
VO2 Max - 79 ml/kg/min
W/kg - 4.9
RobyDogma
by RobyDogma
New custom kicks from BontImage
Skickat från min GT-I9295 via Tapatalk
campbellrae
by campbellrae
Pair of Veloflex Criterium tubs(date stamped July 2012 :thumbup: ) to replace Vittoria Corsa Evo Cx's. Going to have to go back to valve extenders though :( Replacement valves were definitely a big plus on the Vittorias.
Rob1519
by Rob1519
lippythelion wrote:Kermit, I've got two Climbers Jerseys & really like them. Unfortunately the fabric above the pockets is prone to damage and is easily clicked & pulled by sharp corners on bar and gel wrappers.
I have not had this issue with my Climbers Jersey but will be more aware when placing or removing sharp cornered items. Thanks for the heads up!
KWalker
by KWalker
My climbers jerseys have been awful. The white fabric stains super easy and the mesh rips really easily when pinned. The cut is also a bit jacked. I would not buy these if my team wasn't sponsored by Castelli
Gramz
Failed Custom Bike
nismosr
by nismosr
SR Ti crank and SR Dual Pivot Brakeset
Elrey
by Elrey
see you in 45 days!
TimmS
by TimmS
jsprbcn
by jsprbcn
Castelli bodypaint 2.0 black bib
Howies Cadence jersey
dhb goldline jersey
Carrots
by Carrots
New little toy.
