Post new topic Reply to topic  [ 28 posts ]
Go to page Previous  1, 2
 Post subject:
PostPosted: Mon Sep 17, 2007 3:51 am
Topeak Hexus
http://www.topeak.com/2007/products/tools/hexus16.php
160 grams with chain tool and tire levers.
For me a multitool is useless without the chain breaker.
 Post subject:
PostPosted: Mon Sep 17, 2007 7:15 am
I have one question to those proposing the crankbros tool.
Have you ever tried to use the chain tool? It is damn near impossible to break a chain with that thing.
I have one and it is in the bottom of the useless junk bucket in my basement now. :(
 Post subject:
PostPosted: Mon Sep 17, 2007 1:37 pm
I use a Blackburn tool that I can't find a picture of and I don't have time to take one and post. It is 85 grams and includes: 2 real size plastic tire levers, very good chain tool, flat head screwdriver, 3 sizes of spoke tools, 4 sizes of open head hex wrenches (although only really cheap bikes have bolt heads), and 2,3,4,5,6 mm ball head hex keys.
Simply an amazing compact and light tool. I have no idea why they don't make it anymore but probably for the common reason - if its not a new design, its a bad design.
 Post subject:
PostPosted: Mon Sep 17, 2007 2:04 pm
chrism wrote:
For carrying on the road? Nowt, along with good home maintenance. Last time I can remember having a need for any sort of tool on the road was my first ride on the first set of wheels I built, when a spoke key to tighten the rapidly self-loosening nipples would have been handy - but that was nearly 20 years ago. What sort of mechanicals are you guys having?
I carry a Crank Bros Multi 17 also. What sort of mechanicals? None on my bike, but I've had to mend other's bikes often enough. Most recently, it was used on Saturday to tighten my riding companion's rear brake cable.
I can't think of a time I used it on one of my bikes.
 Post subject:
PostPosted: Mon Sep 17, 2007 5:52 pm
Cheers! wrote:
Topeak Hexus
+1 on the Topeak is a bit heavier than most, but has everything you need.
My 2009 SuperSix Hi-Mod
viewtopic.php?f=10&t=60987
 Post subject:
PostPosted: Mon Sep 17, 2007 8:00 pm
Yes, I used the chain tool recently to remove links from a munched chain of a fellow rider on an MTB ride who likes to power shift. No problem with using the chain tool. It worked well.
 Post subject:
PostPosted: Mon Sep 17, 2007 8:01 pm
+1 regarding using the Multi 17 to work on the bikes of other riders.
 Post subject:
PostPosted: Sat Jan 05, 2008 2:28 am
Mine home built, a bit less then 110 g with a real usable chain tool 3,4,5 allens and a phillips one.
I needed to use several tool kits to get one and also some titanium bolts,
I decided to built it after a race where I took 30 minutes to fix a chain... and only after some guys helped me with a real chain tool.
I will post some picks soon
 Post subject:
PostPosted: Sat Jan 05, 2008 3:47 am
crank bros multi 10. no useless chain tool, lighter, but handy w/ larger sized allen keys (for look or crankbros pedals) and also screwdrivers...its good.
www.timetogetmoving.blogspot.com
 Post subject:
PostPosted: Sat Jan 05, 2008 4:36 am
Lightest tools
http://content.mtbr.com/TRD_14_364crx.aspx
89 grams!
:shock:
http://www.lezyne.com/
Was shown at interbike 2007. Not sure if you can buy them yet.
 Post subject:
PostPosted: Sat Jan 05, 2008 4:40 am
This is also pretty darn cool.
http://www.topeak.com/t8/products/tools ... rocket.php
says weight is with the box as well.
 Post subject:
PostPosted: Sat Jan 05, 2008 8:42 am
I use the Serfas Zipper RD. $15USD and super compact. Not to mention ONLY 72 grams! It's perfect.
http://www.serfas.com/product.asp?ProductID=328
www.ChrisDiRe.com
Adam Hansen wrote:
Sponsors should not have to go, its the doped riders that should be shot instead, in the knee caps would be nice.
 Post subject:
PostPosted: Sat Jan 05, 2008 1:35 pm
Like Swinter, this 53g version from Park Tools. It goes in a pouch with an inner tube, a box of tube patches, tyre levers... and an energy gel in case I break down.
I have the large one from Park like Pez for MTB, where more things seem to break or need work.
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
Users browsing this forum: petal666 and 17 guests
There are no new unread posts for this topic. recommend a rear pulley please
Bianchi10
Sun Sep 23, 2012 11:25 am
sugarkane View the latest post
There are no new unread posts for this topic. Recommend me rear V brake hub?
in MTB
blingUK
Fri Jul 13, 2012 6:47 am
fadr View the latest post
There are no new unread posts for this topic. Recommend a carbon frame under £2300
liam7020
21
1400
Mon May 13, 2013 6:07 pm
Beancouter View the latest post
There are no new unread posts for this topic. Recommend a rigid fork? Weight/Value?
in MTB
hungryalex
Mon May 06, 2013 9:58 am
anicomp568 View the latest post
There are no new unread posts for this topic. recommend me a <$20 scale for weighing parts
odin99
Sun Mar 03, 2013 4:05 am
vwo05 View the latest post
It is currently Tue May 21, 2013 8:14 am
