It is currently Wed Jan 17, 2018 2:09 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
PostPosted: Thu Sep 07, 2017 9:49 pm
Parallel with the ground or inline with the stem?
PostPosted: Thu Sep 07, 2017 11:42 pm
Inline with the stem or it would look odd.
PostPosted: Fri Sep 08, 2017 7:15 am
Parallel with the ground would also not be the best angle for viewing.
Colnago C59
PostPosted: Fri Sep 08, 2017 8:37 am
That's interesting, although all the peleton run theirs parallel.
PostPosted: Fri Sep 08, 2017 10:53 am
All, huh? Then, of course you must copy them. :-)
Colnago C59
PostPosted: Fri Sep 08, 2017 12:06 pm
I'm sorry, I hadn't realised that your opinion was the final say on the matter, would the moderators please close this thread as there's no more to discuss.
The answer is inline with the stem everyone.
PostPosted: Fri Sep 08, 2017 12:32 pm
Really, I think it is a legitimate question. It was partially address here : viewtopic.php?f=3&t=122718&start=30
There were some wind-tunnel tests done @ Specialized a few years ago (on YouTube, I think). I find it odd that this community debates the weight savings of a single chainring bolt or the excess weight of decals on a wheel, but mocks the suggestion of marginal aero gains anywhere on the bike.
Personally, I prefer my BOLT (and Garmin, before that) to be perfectly level with the ground and I use a bubble-level to orient it. Everyone has their own preference, and this is simply my preference. When I see other riders who have a computer or smartphone angled upward at 45-degrees like a laptop computer, I can't help but wonder if the aero impact is actually measurable (but perhaps not meaningful).
(donning my flame suit)
PostPosted: Fri Sep 08, 2017 12:42 pm
I already feel it would be best for all of us.
Sent from my SM-G920I using Tapatalk
PostPosted: Fri Sep 08, 2017 12:43 pm
+1 for parallel to the ground.
-10,000 for 45 degrees up (which I see alarmingly often)
No longer in the industry
PostPosted: Fri Sep 08, 2017 1:32 pm
Parallel. Inline with stem looks terrible if your stem isn't parallel to the ground.
PostPosted: Fri Sep 08, 2017 6:06 pm
Man, you are sensitive. I never said I had the final say on this. There is no right answer. The only right answer is how you like it.
Colnago C59
PostPosted: Sat Sep 09, 2017 5:25 pm
for me parallel to the ground
PostPosted: Sun Sep 10, 2017 12:02 am
Level with the ground, always. At the very least, level with the hoods.. which I keep largely parallel to the ground. Parallel with the stem doesn't really make sense if you have an extreme angle up or down..
BMC Teammachine SLR01 (2018) | Rodriguez Rainier (2015)
PostPosted: Sun Sep 10, 2017 12:23 am
Level with the ground.
Pretty sure DCR had a few configurations in the win tunnel and found that to be the most aero out front position. Interestingly enough that still tested less aero than the rubber band stem mount.
PostPosted: Sun Sep 10, 2017 3:29 am
A bit in-between, honestly.
Not making it up to be an instigator!
Pointed up just a hair beyond parallel.
And just a bit shy of matching the stem.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
There are no new unread posts for this topic. Attachment(s) Front chainring position
in MTB
02GF74
Fri Jul 28, 2017 2:06 am
CycloTron View the latest post
There are no new unread posts for this topic. Out-Front Mount Request - to hold a Garmin 500 & Bontrager Ion 700
Matt28NJ
Thu Jan 26, 2017 3:56 pm
SpecializedColnago View the latest post
There are no new unread posts for this topic. Saddle Position while using Clip-on TT bars
dmulligan
Wed Jul 26, 2017 3:32 pm
jekyll man View the latest post
There are no new unread posts for this topic. Cleat position when ur feet are not same length..
3Pio
9
818
Mon Sep 04, 2017 4:47 pm
3Pio View the latest post
There are no new unread posts for this topic. Saddle widths and riding position
cmcdonnell
11
1558
Tue May 16, 2017 9:52 am
DJT21 View the latest post
Users browsing this forum: benzebub, Rudi and 9 guests
cron
