Cycling on the wet leaves is possible?
by PaulSD
Are wet leaves slippery for cycling?
by spdntrxi
by Sleepless
Best thread ever! :D
by Calnago
"Are wet leaves slippery for cycling?"
Not if you have disc brakes :). They fix everything. Ask the pros.
by evan326
Are they slippery to run on?
by Steve_W
Sleepless wrote:Best thread ever! :D
I'd agree.
by kulivontot
Can we ditch the 50 post requirement or even the discounts / incentives altogether? This forum is filling up with garbage off topic posts.
by mattr
It is a hilariously novel way of bumping his post count though.
by dj97223
Is the Pope Catholic?
by fromtrektocolnago
Calnago wrote:"Are wet leaves slippery for cycling?"
Ever climb on 17% gradient with wet leaves.....Don't
I knew better too. Fortunately nothing too bad went wrong. Just a little scary for a moment. Maybe I should've had disc ;)
Colnago C-59 (Dura Ace)
Trek 5200(ultegra)
by Calnago
Yes, you would have had no problem with discs.
by Stolichnaya
Cycling on wet leaves is only safe above 40 kph.
by AZR3
The real question is which is better on wet leaves, an aero frame so your faster and spend less time on the wet leaves or a lightweight frame so you don't apply as much pressure to the wet leaves......discuss! Lol
by jimaizumi
Well, I did the most educated thing before posting a reply and checked his 7 posts. He's made comments on balancing to braking power on Enve's so I've decided to say this.... Dude, really? Didn't you know wet oak leaves are more slippery than birch but birch has a greater contact patch than sakura.... This is only if you're riding on tarmac but watch out for those Kapok trees in the amazon jungle... They can be pretty killer during the months of June to August but are perfectly "unslippable" from January to March...
Hope this helps...because if this is a serious question, you're not going to get any serious answers.
:oops: THE PAST: 2005 Cannondale R700, 2006 Specialized S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
:D THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato
:wink: THE FUTURE: :mrgreen: :mrgreen:
Powerful Pete
Location: Lima, Peru and occasionally in the Washington DC area.
by Powerful Pete
Locking this one for posterity.
Supercommuter: Jamis
