Garmin Edge Mount
I have the original mount from my 810. Upon closer look.. It seems something like a GoPro mount count be screwed into here?
But didn't see any options from garmin for that.
Just trying to see if I can get the bottom part instead of buying a kEdge.
Thx.
Thx.
- ALAN Carbon+
Saw this on eBay the other day that might work with the original Garmin mount http://www.ebay.co.uk/itm/121984500721
Sent from my 0PJA10 using Tapatalk
- WheresWaldo
- in the industry
@addictR1
You might be able to make it work, What are the center-to-center dimensions of the holes?
Here is how it might work.
If it's 20 mm you can use a K-Edge combo interface and two flat head screws, Remove the Garmin mount, put the screws in from the top and replace the garmin mount. Attach the K-Edge interface to the now exposed threads on the bottom of your mount. Use nuts to secure it.
If that doesn't work then PM me and maybe look at this thread, I might be able to help you out.
Camera Mounts and Assorted 3D Printed Parts
