What is this bolt/nut thing and where can I get it in Ti ?
- prendrefeu
- Contact:
It's a recessed nut, by definition. Recessed nuts are used on mounting brake calipers - however the standard for that is completely different from the one in hand. The one in hand has a female m5 thread (the brake caliper variety is m6) and it's much shorter. The closest spotted so far is the 3T package with accompanying bolts (which I don't need).
On an integrated handlebar there's only one area where there is a bolt: the stem to steerer clamp area. On two different integrated bars they were designed without threaded bonded into the carbon, instead they use a recessed female nut mating to a male bolt on the other side...
Recessed brake nut:
http://www.biketweaks.com/titanium-bolt ... -nut-m6X10
But yours looks even smaller than 10mm
