Camera Mounts and Assorted 3D Printed Parts
WheresWaldo
by WheresWaldo
@cDaero, I finished up mounts that match the one you posted with a Wahoo Fitness mount instead of Garmin. It is approriately sized for ELEMNT or BOLT devices (it is not aero shaped). It is a combination of Wahoo, GoPro and uses the integrated stem mounts from Bontrager or BMC.
Here are links to the 3D model
ELEMNT sized
BOLT sized
Here is the Shapeways page link, please note sizes are SMALL & LARGE, as listed in the description.
cDaero
by cDaero
Very much appreciated!
Bikeboy73
by Bikeboy73
@WheresWaldo
I have been searching the Internet for a Wahoo mount as a replacement insert to the Garmin on my 3T Integra stem, but no luck. Maybe I have been looking in the wrong places?
Now I have bought an adaptor (maybe yours @WheresWaldo?) from Shapeways, but it just does not look as (aero) smooth with my Elmnt Bolt as it could with a proper insert instead... The adaptor builds some 7 mm or so. A Wahoo Elemnt Bolt insert would really go well with the aero design of the Bolt!
My current setup, with an adaptor: https://photos.app.goo.gl/76rpmy7UGKosDI6O2
Have you created any such insert for the 3T Integra stem integrated mount?
https://roadbikeaction.com/rba-tech-3t- ... -ltd-stem/
glepore
by glepore
@bikeboy-not to jump in, but what I did with an integra on the Cento was to take out the garmin adaptor and put in a Kedge wahoo puck-its bright blue and doesn't fill the space fully, but the wahoo mounted on it looks awesome. I had to glue it in place, but suspect it could be removed and revert back. Doesn't look all that good when empty, but who cares? Painiting it black would solve that.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
WheresWaldo
by WheresWaldo
@Bikeboy73
I could do something with that. I have never seen that Garmin mount in person, but with proper dimensions I could build something that would work. Where are you located? It would attach at the two read screws because the front screw would interfere with the Wahoo locking tab but I think that would be enough. Just let me know if you want me to work on something like this.
Bikeboy73
by Bikeboy73
Thanks @glepore!
This solution has crossed my mind as well... since I do have a 3D printed puck or adaptor for the Garmin mount, that turns it into a Wahoo mount. I guess this will be Plan B. ;-)
Appreciate your comment!
Bikeboy73
by Bikeboy73
Thanks for the quick reply @WheresWaldo!
I am however located a few bike rides away from you... in Sweden, but I will check the critical measurements (L x W, screw holes position, others?) and get back to you, and you could judge if that is good enough to start up something like this.
Bikeboy73
by Bikeboy73
@WheresWaldo
I have now added a sketch of the Garmin insert to my shared album
The only missing measurement would be the thickness; 5.5 mm
Please check if this is all you need for a design! Thanks!
WheresWaldo
by WheresWaldo
@Bikeboy73
Are the screws M3 flat head or socket head? How long are they?
WheresWaldo
by WheresWaldo
Here is a mock-up http://a360.co/2IFQLkc
Not finished until you tell me what size the screws are and whether or not they are recessed.
Bikeboy73
by Bikeboy73
Flat head 7 mm long T8 screws. Recessed ca 4 mm.
There are also a square 2.5 mm cutout at the base, centered, as well as one 4.2 mm at the top. See added picture of the insert upside down in the album.
But I could probably cut that out with a sharp knife... 😎
WheresWaldo
by WheresWaldo
T8 is the size of the Torx (Star) I am still assuming they are 3 mm threads? If you tell me the measurements of the two locating recesses I will model those in from the start. That is super easy to do. I also assume the recesses are equal on both sides and centered.
Maybe after you get yours, we can convince @glepore to get rid of the glued adapter.
WheresWaldo
by WheresWaldo
One last note, because of the design of the Wahoo mount, the insert modeled here is 6 mm thick. so it will stick up ever so slightly. I can see how much I can pare it down to get as close to 5.5 mm as possible.
Nevermind, it is now 5.5 mm thick
Bikeboy73
by Bikeboy73
Yes i do think the threads of he screws are 3 mm.
The recesses, centered at top and bottom, are actually different in size: 2.5 mm wide at the base, and 4.2 mm wide at the top. They are approximately 2 mm deep. (Tricky measuring these small things!) I tried to take a picture of the insert upside-down but it turned out so-so...
https://photos.google.com/photo/AF1QipP ... Znzx5-sbzR
Really appreciating your work!
WheresWaldo
by WheresWaldo
@Bikeboy75, done
I will upload the model to Shapeways right away and post a link for you and every other 3T Integra owner.
