Camera Mounts and Assorted 3D Printed Parts
- WheresWaldo
- in the industry
Here is a link http://shpws.me/Q12E Wahoo 3T Integra Stem Insert
Thanks ... you were under the weather when I needed mine and did'nt want to disturb you. I think I have the garmin insert if you want it mailed to you to confirm dimentions...have to dig around a bit in the dustbin. Let me know.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6. ; Anvil Custom steel Etap;1996 Colnago Technos Record
- WheresWaldo
- in the industry
@glepore
Yes, I had to have some kidney stones surgically removed. Too big to pass, too big to break up, surgery was the only option. The pain was incredible, had to wait two months before I could have the surgery. All better now. If you find it I wouldn't mind seeing it. That way I can double-check all of @Bikeboy73's dimensions, even though I do trust them.
Found it, have no need. I cleared out my pm's, shoot me an address and its on its way.
- WheresWaldo
- in the industry
@glepore
PM Sent
PM Sent
- WheresWaldo
- in the industry
If anyone has been reluctant to model their own 3D mount buy a 3D printed mount from Shapeways maybe this will incent you to try. Use this referral code and get 15% off your first order of a model of your own design. Might be really good for someone who wants to dabble in making their own.
FU1V2
I usually don't get codes emailed to me at all, this is the first I have seen in a very long time. I wished Shapeways would do this more often.
FU1V2
- WheresWaldo
- in the industry
@glepore, Insert arrived, It doesn't look like it is a very robust part. There are chunks missing in it. @Bikeboy73 did a great job measuring his insert, only one measurement was slightly different between your insert and his drawing.
I think the chunks missing are areas where i nipped the insert to use it with the wahoo, the wahoo fits like that but it doesn't lock like it does with a wahoo part.WheresWaldo wrote: ↑Tue Mar 27, 2018 3:42 pm@glepore, Insert arrived, It doesn't look like it is a very robust part. There are junks missing in it. @Bikeboy73 did a great job measuring his insert, only one measurement was slightly different between your insert and his drawing.
- WheresWaldo
- in the industry
Ahh, understood. I still think you should get my insert. It will look better and appear as if it was made by 3T.
Will do. What size were the tiny screws I inadvertently included wit the Garmin piece?WheresWaldo wrote:Ahh, understood. I still think you should get my insert. It will look better and appear as if it was made by 3T.
- WheresWaldo
- in the industry
M3 x 3 mm probably longer ones fit, and my model should be M3 x 6 mm for the two at the bottom
Thanks Waldo! Once an engineer, always an engineer I guess...
About to recieve my insert this week...!
Recieved my 3T Integra stem insert for Wahoo Bolt today. Very happy with the result, thanks @WheresWaldo!
https://photos.app.goo.gl/76rpmy7UGKosDI6O2
