It is currently Sun Aug 20, 2017 7:11 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Tue Apr 29, 2014 8:58 pm
jekyll man wrote:
From what I've seen which isn't exactly a scientific study, Retul normally results in saddles going up by about 30mm and causing problems.
this is true...when i got fitted on a Retul, my seat shot up about an inch or 30mm like you said. i didn't care for it. i dropped it back at least 20mm. did not like the Retul much. thinking about getting a fit on the Guru system.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Tue Apr 29, 2014 8:59 pm
oops. duplicate post.
PostPosted: Tue Apr 29, 2014 9:00 pm
Use your phone on a stand behind you when riding the trainer to record yourself and verify whether or not your hips are rocking. There are apps for this made to help you "draw angles" on top of your videos which can be of great help.
A cheap goniometer from ebay is also great to verify the seat height by measuring knee extension angle at bottom of the pedal stroke stroke. 30-35 degrees is often considered what you should aim for - http://velonews.competitor.com/2013/08/ ... als_297968
PostPosted: Wed Apr 30, 2014 2:05 am
I have to say I had gotten used to a very low seat position coming from Down Hill mountain biking and general freeride pre dropper post and there was no doubt I was sitting too low.
I will have my normal riding partner check for hip movement he is used to seeing me ride. It feels like its more the longer extension of the leg that has given a different wear. The last couple of ride it has been better and I have gotten home without any problems but I have also used chamios buttr to prevent it.
There are no new unread posts for this topic. Sore Foot
shoemakerpom2010
10
691
Mon Apr 17, 2017 4:11 am
Mep View the latest post
There are no new unread posts for this topic. Carbon seat + post : Remove bracket/rails and attach seat directly to post - bonding?
alcatraz
Sun Oct 23, 2016 4:07 am
KarlC View the latest post
There are no new unread posts for this topic. Attachment(s) Seat rail adapter for a carbon seat rail??
theyoungconnoisseur
Tue Jan 31, 2017 2:44 pm
theyoungconnoisseur View the latest post
There are no new unread posts for this topic. Additional seat clamp
zazo
14
884
Fri Jan 13, 2017 8:16 am
Fiery View the latest post
There are no new unread posts for this topic. Seat Post Question
KCookie
Thu Feb 09, 2017 1:36 am
KCookie View the latest post
Users browsing this forum: No registered users and 7 guests
