It is currently Tue Jan 23, 2018 9:19 am
PostPosted: Fri Apr 25, 2014 10:14 am
I'm pretty sure I figured out that my leg warmers sometimes gives me cramps, my legwarmers are really tight and has the stitches on the backside and after some time they start to fold up behind the knee. My veins pop out a little on the legs and my muscles are very soft so I believe that the warmers close up my blood circulation, I think my theory was proven today. I went for 1½ hour ride today very easy, after 1 hour the cramp started in my rear thigh where it always starts and exactly where the fabric folds and where most of my veins are visible.
I'm looking for a good fit, assos could the ones, what else is on the market? any seamless?
PostPosted: Fri Apr 25, 2014 7:42 pm
Specialized make some that are knee shaped. Mine have seams on the side, not front or back, and they're flat seams which I don't notice.
PostPosted: Fri Apr 25, 2014 9:03 pm
Not waterproof, nor super warm, but these are the most comfortable leg warmers I've used. They're knit, so they bend around your knee just like a sock bends around your heel. Good from 5˚ to 18˚ or so, I frequently wear them in place of knee warmers in the spring and fall because they breath so well.
http://velonews.competitor.com/2013/11/bikes-and-tech/clothesline/reviewed-giordana-dryarn-knit-leg-warmers_310099
VeloNews Magazine/VeloNews.com tech
PostPosted: Sat Apr 26, 2014 12:26 pm
I have the Assos LegUno_S7. I'm pretty happy with them and use them a lot. Mostly on spring and autumn rides in combination with the Assos T.équipe_s7 shorts. But also in winter, as they are warm enough for winter rides in combination with an Assos T.607_s5.
They have seems, but I've never noticed them.
PostPosted: Sat Apr 26, 2014 2:12 pm
I like smart wool knee warmers, they have no seams and of course breathe. They are cheap and work great for the early spring and summer rides.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
PostPosted: Sat Apr 26, 2014 4:52 pm
I think you will need to get better fit. Improve your cycling fitness and cramps will go away.
First make sure you got the right size leg warmers.
Then go out and train to improve your fitness.
PostPosted: Sat Apr 26, 2014 5:13 pm
I worked in a cleanroom for a couple of months (worst job of my life :mrgreen: ) and had to wear this horrible suit that had straps around my calves. The pain in my calves was so severe I could barely walk. And I was in the best shape of my life then, I was doing xc races and mtb marathons at the time. I was the only one experiencing this. I guess they were restricting the blood flow by pressing on some bloodvessels.
So these cramps don't mean that he is in bad shape.
PostPosted: Sat Apr 26, 2014 5:21 pm
Did you read my second line? :smartass: :noidea:
PostPosted: Sun Apr 27, 2014 6:17 am
thanks for the replies everyone. stella-azzurra here are some numbers from the ride:
Distance 38.6km
Moving Time 1:26:36
Elevation 298m
avg. max.
Speed 26.8km/h 55.4km/h
Heartrate 122bpm 153bpm
Cadence 86 107
Power 149W 403W
Calories 865
my ftp is around 265 and max puls 180
the warmers are the right size just not the right fit for me, my skin turns red behind the knee form the fold ups and the stitching. It doesn't matter if the warmers are not to blame for my cramps I just want leg warmers that are warm with a really good fit , it doesn't need to be seamless
PostPosted: Mon Apr 28, 2014 1:28 pm
Assos warmers are good. However I've found that the sort of shorts you wear depend on their performance (because they don't have any upper-thigh grippers).
Worn underneath Assos bibs they are great. When used with cheaper Nalini shorts they slide down a bit. IMO they presume that a fair amount of compression is applied by the shorts (both in terms of the lycra and the silicon/rubber grippers).
There are no new unread posts for this topic. Green knee warmers
nafaiutb
Thu May 11, 2017 8:39 pm
nafaiutb View the latest post
There are no new unread posts for this topic. Pas normal Studios Arm warmers (Brand new)
Bianchi10
Mon Dec 11, 2017 10:09 pm
Bianchi10 View the latest post
There are no new unread posts for this topic. Assos Arm Warmers latest version
Mr.Gib
Thu Sep 21, 2017 1:42 am
TonyM View the latest post
There are no new unread posts for this topic. FS - Clearing out all of my MAAP - Jacket, vest, jerseys, bib shorts, warmers...
Bianchi10
Thu Jan 11, 2018 1:45 am
Users browsing this forum: Bing [Bot] and 7 guests
