It is currently Mon Jan 22, 2018 5:41 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Wed Jan 15, 2014 10:15 am
Anyone else have issues with bolts and components coming loose during the winter months?
I find I have to be extra vigilant with stem and seatpost bolts (among others) when the weather drops near or below freezing. In particular, carbon seatposts seem to creep further and further into the frame during the course of a ride. I worry about over-torquing bolts, especially when using carbon components, so I use a torque wrench, but it seems like everything needs to be snugged a little tighter when it is cold outside.
The areas I seem to have the most issue with are seatpost clamp, saddle clamp, stem, and shifter clamps, front derailleur clamp, bottle cage bolts. I use carbon fixing paste where appropriate, but it doesn't always help.
PostPosted: Wed Jan 15, 2014 5:05 pm
I don't have any problems, but thermal expansion/contraction is an additional factor that could contribute to loosening.
I use carbon-paste on seatpost & stem, but I also use loctite on virtually every threaded fastener.
I know there are purists who don't like loctite for some reason, but I use it everywhere, and it works.
PostPosted: Thu Jan 16, 2014 5:03 am
We ride in pretty cold weather, but I have never experienced that.
PostPosted: Fri Jan 17, 2014 2:43 am
If any fixing isn't holding at the recommended torque setting, well then it needs to be tighter than that.
PostPosted: Fri Jan 17, 2014 8:46 am
Having worked on nuclear submarines, warships, and military aircraft, I am used to multiple torque settings based on temperature. I'm surprised the same doesn't apply for bike components.
PostPosted: Fri Jan 17, 2014 10:37 am
Slight differences in tolerances can cause this.
Use Loctite instead of grease or anti-seize.
PostPosted: Fri Jan 17, 2014 11:09 pm
A) Because the temperature range generally isn't large enough.
B) The bike isn't designed as a system, it's just a load of bits from different manufacturers bolted together.
Only place I can see it being a major issue is seatpin/seattube. Especially large diameter ones. And material dependant.
I.e. carbon/carbon shouldn't be an issue, add some aluminium, you might come unstuck.
Also, it's worth bearing in mind that cold weather usually means rain, which can act as a sort of thin film lubricant in some cases. (A mates seatpin always used to slip in the rain, no matter what the temperature)
PostPosted: Fri Jan 17, 2014 11:40 pm
I had that for many years ago as i still was cycling with aluminium parts and frames. Felt that mostly at the stem which was getting loose on some days as i took a bike out from the warm livingroom and cycled at a cold winterday.
:arrow: my 36XXg Stevens
:arrow: my Litespeed
PostPosted: Sat Jan 18, 2014 2:12 am
mattr wrote:
Also, it's worth bearing in mind that cold weather usually means rain, ...
Let's not improperly extrapolate one's own specific conditions as universally applying wrote:
Well, maybe where you ride, but not everywhere.
And if it's raining (unless of the freezing variety), it's not very cold, at least by many people's standards.
PostPosted: Sat Jan 18, 2014 2:55 am
Because bikes don't blow up, sink or crash killing lots of people if something works loose.
PostPosted: Sun Jan 19, 2014 3:18 pm
True, but I have seen more cyclists than Navy personnel injured from things working loose.
PostPosted: Sun Jan 19, 2014 4:06 pm
Here's what happened to me two years ago, it's definitely related to changes in the temperature vs thermal expansion/contraction. Stem was perfectly fine a couple of weeks earlier (sub 15 deg C back then) but somehow all four bolts got loosen at almost the same timing! And the torx bolt didn't help either as I lack the particular size in the multitool... :(
Had to resort to walking a couple of kilometers in cycling shoes to get to the nearest bikeshop for assistance.
Since the incident, I've applied threadlock on all Ti bolts, particularly on the stem/steerer for safety reasons.
PostPosted: Sun Jan 19, 2014 4:12 pm
maverick_1 wrote:
Here's what happened to me two years ago, it's definitely related to changes in the temperature vs thermal expansion/contraction. Stem was perfectly fine a couple of weeks earlier (sub 15 deg C back then) but somehow all four bolts got loosen at almost the same timing!]
How recently had the torque of the bolts been checked? How many kilometres had been ridden since then?
PostPosted: Sun Jan 19, 2014 4:17 pm
TBH, cold where I ride is usually going on -20C. And i have no issues with cold. Except fork seals. So I only run rigid.
The OP refers to near or below freezing. Hence rain.
PostPosted: Mon Jan 20, 2014 12:38 am
This happened to me a few years ago. Subzero temperatures during an MTB marathon. Over the course of the race the aluminium disc rotor bolts I was using all worked loose.
Fortunately I used 3 Ti and 3 Al on the front rotor and the Ti stayed tight. The 6 on the rear rotor were all Al though, and the rotor fell off the hub.
I'm suspect it was related to thermal contraction of the aluminium.
There are no new unread posts for this topic. Cold weather gear
Thenuge
24
2924
Thu Nov 16, 2017 10:12 pm
jfranci3 View the latest post
There are no new unread posts for this topic. Gabba / Perfetto alternatives for cold weather riding.
nemeseri
Thu Dec 28, 2017 1:30 pm
Titusrider View the latest post
There are no new unread posts for this topic. Bike materials: steel, alloy, ti, carbon and cardboard ....!! Yes that is right cardboard.
Neckkoss
Wed Aug 30, 2017 2:28 pm
ManekiNico View the latest post
There are no new unread posts for this topic. Riding or not when having cold/flue/fever?
in Training
3Pio
19
2178
Thu Nov 23, 2017 3:00 pm
charlieboy52000 View the latest post
There are no new unread posts for this topic. Cooler weather clothing
Boshk
14
747
Wed Jan 03, 2018 10:00 pm
TonyM View the latest post
Users browsing this forum: Bing [Bot] and 7 guests
