It is currently Mon Jan 22, 2018 7:41 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page 1 2 Next
PostPosted: Thu Jan 02, 2014 1:38 pm
Anyone have any experience with this? Is it a viable alternative to the Garmin model? It seems to be cheaper but I can't find much information on it.
I'm specifically interested in how it interacts with the Garmin computer itself (Edge 500 in my case).
http://www.dcrainmaker.com/2012/02/bont ... ensor.html
Campagnolo; because it's a bicycle, not a fishing rod.
PostPosted: Thu Jan 02, 2014 1:46 pm
Easy to install and no problem with any Edge 500/510/800/810.
PostPosted: Thu Jan 02, 2014 2:46 pm
Using the Bontrager ANT+ Cadence only sensor with Edge 500, not one glitch in 10.000+ km, only on its second battery. The Edge seems to find it very quick too at startup.
The Shivenge
PostPosted: Thu Jan 02, 2014 3:10 pm
I used to run one on my edge 510 before i broke it ,so replaced back with a garmin ,as it was the only one they had in the shop ....they both seem to work just as good as each other for me :D
PostPosted: Thu Jan 02, 2014 3:42 pm
Dcrainmaker once mentioned that all of these sensors are identical, since they are all made at the same place in China, but with different brand / packaging. The plastic case may be a bit different, but they all work the same. I have a Motorola branded one, and it works fine.
PostPosted: Thu Jan 02, 2014 5:19 pm
Top tip of the day is to always ditch the cadence sensor magnet for the crank, and place a strong neodymium magnet on the pedal axle (works less well with ti axles...), the magnet doesn't even have to pass anywhere near the cadence sensor.
IMO very nice not having to keep a 2-3mm clearance, I have atlest 15mm clearence as that is where the sensor points straight down under the chain stay.
The Shivenge
PostPosted: Fri Jan 03, 2014 6:11 pm
It's an ANT+ system, so it will work with no issues.
I had the cadence sensor on my old Madone, which didn't have the pocket for the DuoTrap sensor. I found that the sensor worked just as well, if not better than the Garmin sensor (as opposed to the Node head units - first versions, at least - which were absolute garbage). The battery life was better than the Garmin units for an equal amount of distance travelled.
One of the benefits of the Bontrager system vs. the Garmin is that the crank arm magnet was not attached to the arm, but was part of a rubber band system. I preferred it over the other magnet systems.
Oh, and if you are using a Garmin with GPS, why not just get a cadence sensor, and let the Garmin determine speed based on GPS?
PostPosted: Fri Jan 03, 2014 7:55 pm
Using the GPS for speed works less than well on a trainer, AFAIK atleast, but never tried it myself. ;)
The Shivenge
PostPosted: Fri Jan 03, 2014 9:29 pm
GPS won't work on a trainer, because you aren't moving ;)
PostPosted: Sun Jan 19, 2014 3:17 am
I have three of the Bontrager Sensors on my bikes, all very good. Smaller than some of the other sensors out there and easily pairs with Garmin as well as SRM head units.
PostPosted: Mon Jan 27, 2014 12:30 am
I use one to measure speed on the turbo trainer, using a Garmin 800. I remove it for outdoor riding. The rubber band fitting is good for this. Works just fine.
I'm using a different magnet on the wheel which is a bit more robust.
PostPosted: Mon Jan 27, 2014 10:34 am
I ended up buying this however have issues with the cadence, it just doesn't pick up 98% of the time, even if the crank is touching the unit. I will try DMFs suggestion.
Do you have a link to source one?
PostPosted: Mon Jan 27, 2014 3:30 pm
Online
On a side note, does anyone know if using the bontrager duotrap means it will override Garmin's speed calculations by gps? Or will the Garmin unit somehow toggle between the two? I sometimes go through the city centre with tall buildings all around and noticed that the speed display goes crazy...
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Mon Jan 27, 2014 4:05 pm
The magnetic speed is calibrated from the GPS, so I assume the computer combines the two.
PostPosted: Sun Nov 15, 2015 10:54 am
Sorry to dig up an old thread but as this is WW, does anyone have the weight of it compared to a Garmin GSC-10?
There are no new unread posts for this topic. Speed/ Cadence sensor needed?
addictR1
Sat Nov 11, 2017 2:59 am
stuh View the latest post
There are no new unread posts for this topic. Wahoo RPM cadence sensor & Rotor cranks
naylor343
Sat May 06, 2017 10:13 am
naylor343 View the latest post
There are no new unread posts for this topic. SRM speed sensor not connecting to Garmin 500
TomColnago
11
284
Sat Jan 06, 2018 7:47 pm
TomColnago View the latest post
There are no new unread posts for this topic. Bontrager speed limit on wide rims
Attermann
Mon Aug 07, 2017 5:04 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Bontrager Speed Limit XXX brakes missing barrel
estebanaznar
Sat Jul 01, 2017 4:51 pm
estebanaznar View the latest post
Users browsing this forum: No registered users and 13 guests
cron
