It is currently Sat Mar 25, 2017 1:17 pm
 Post subject: Cutting a seatpost.
PostPosted: Sun Oct 27, 2013 2:24 pm
Just bought a Titanium Airborne seatpost. Its 33cms long. I usually use a 10cm length to ride. I want to cut 10m of the post to lose weight, is that safe to do? It will leave me with 23cms. 13 cms of the seatpost in the frame and 10 outside. Its supposed to be bulletproof, so I just want to trim it somewhat. Your thoughts thanks.
 Post subject: Re: Cutting a seatpost.
PostPosted: Sun Oct 27, 2013 4:51 pm
Administrator
Stop being in doubt, get the pipe cutters or the hack saw out.
I you want to go even lighter, you can also make a diagonal cut like Ritchey does with its posts.
Please next time post this in Road or MTB forums. :thumbup:
Quote:
PostPosted: Tue Nov 05, 2013 2:31 am
+1. I did the same. Just watch your minimum insertion length and it will work fine.
2015 Specialized Crux Pro
2013 BMC TMR01 custom build
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
1980 Palo Alto custom build
PostPosted: Tue Nov 05, 2013 8:03 am
If your weight is that of a typical cyclist, you can probably cut off 16cm of post.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
PostPosted: Fri Nov 22, 2013 9:58 am
Thanks guys. I just bought a Moots 40cm post, 27.2 there's no insertion marks, I'm about 105kgs how much do you think I can cut of safely thanks :D
PostPosted: Fri Nov 22, 2013 10:54 am
Administrator
With a titanium post you could get by with as little as 70mm inside the frame. For me personally my number is I like at least a 100mm in the frame.
RESIDENT GRUMPY OLD MAN.
PostPosted: Fri Nov 22, 2013 6:59 pm
you want the bottom of the seatpost to extend past the bottom of the top tube at the TT/seat tube junction by at least 2cm. this prevents lateral forces from stressing that joint and "twisting" your top tube off the seat tube. otherwise you should be fine.
PostPosted: Mon Dec 02, 2013 10:06 am
You may have some issues if you cut 10 metres off your post ;)
Campagnolo; because I ride a bicycle, not a fishing rod.
M∆SON Definition / Camapgnolo endurance & bikepacking build - ~8.4kg
There are no new unread posts for this topic. Cutting a carbon seatpost
MattSparkes
20
2205
Mon Dec 19, 2016 6:19 pm
kode54 View the latest post
There are no new unread posts for this topic. steer tube cutting questions
blondie
Wed Mar 30, 2016 2:07 am
blondie View the latest post
There are no new unread posts for this topic. Too much seatpost?
SlowSprinter
18
1663
Mon Oct 24, 2016 12:59 pm
SlowSprinter View the latest post
There are no new unread posts for this topic. 31.6mm seatpost
in Wanted
xc4me
Fri Mar 03, 2017 3:05 am
xc4me View the latest post
There are no new unread posts for this topic. WTB: 31,6mm seatpost
in Wanted
victaras
Thu Jan 05, 2017 8:58 pm
victaras View the latest post
Users browsing this forum: Google [Bot], Wookski and 8 guests
