It is currently Fri Jan 19, 2018 11:03 pm
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: Assos confusion/advice!?
PostPosted: Sat Aug 17, 2013 5:18 pm
Hi
I am looking at a pair of Assos Airblock tights and a pair of Assos Airblock 851 tights, other than the price, whats the difference!?
Which do people prefer!?
I am quite confused with a lot of the Assos models tbh! Are they all basically the same or is it worth spending the extra?
thanks
PostPosted: Sun Aug 18, 2013 4:28 am
One has chamois and the other doesn't? Guessing.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Sun Aug 18, 2013 4:49 pm
nope...neither have chamois!
still perplexed!?
PostPosted: Mon Aug 19, 2013 4:58 pm
Moderator / Brake Pad Boy
Please be more precise about the products numbers. Which Airblock Tight do you mean, for your information the Airblock Tight 851 is discontinued for quite some time already.
Colnago extreme-C Scott Addict SL
PostPosted: Mon Aug 19, 2013 5:17 pm
i have the 851 and i think they are basically the same but the 851 has the updated (dimpled) type of wind blocking fabric?
i have both 851 and airprotec tights but have been using the Assos tK.607_S5 Bib Knicker down to 35° F.
if you are set on tights i would consider the tights w/ chamois unless you ride in extremely cold conditions
having to wear bib shorts under thicker bib tights to me feels bulky and a little confining
PostPosted: Tue Aug 20, 2013 2:49 pm
ok was looking at the difference between these two...
http://www.assosfactoryoutlet.com/men/k ... -1924.html
http://www.assosfactoryoutlet.com/men/k ... -1895.html
PostPosted: Tue Aug 20, 2013 3:22 pm
I think the titanium ones are about 3 years older than the 851s..
The 851 has a windproof panel (same used on the airblock/ airjack jacket) on the front of the thighs and knees, dont think the older ones do.
Ive got a pair of the 851s and i've used them about 20 times in over 5 years; they're a bit overkill for the UK. They're fairly restrictive.
IIRC they also did one of the 851s with less windblock.
Available with or without chamois...
Official cafe stop tester
PostPosted: Thu Aug 22, 2013 10:12 am
Thanks, if last winter was anything to go by the 851's might be just what i need!
Now need to decide which to go for :?
PostPosted: Mon Sep 09, 2013 1:37 pm
The factory outlet link posted above has a lot of options and decent pricing. I am thinking the 851 or the Winter S5's. I've used the RX LL for the past two seasons and they were pretty good down to just about freezing.
There are no new unread posts for this topic. Colnago headtube bearings confusion - please advice
PixelGarden
12
1305
Fri Feb 17, 2017 7:57 pm
AJS914 View the latest post
There are no new unread posts for this topic. Crank length confusion
Greatestalltime
19
1853
Tue Jul 18, 2017 1:46 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. SRAM Red Chainring confusion
TimW
11
1000
Mon Jul 24, 2017 5:35 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. Assos & Castelli bib sizing?
dastott
Sat Dec 09, 2017 2:39 pm
kode54 View the latest post
There are no new unread posts for this topic. Assos customer service
markyboy
30
2059
Sat Oct 28, 2017 11:21 pm
sfo423 View the latest post
Users browsing this forum: No registered users and 5 guests
