DeMarchi Bib Short Sizing
mdeth1313
by mdeth1313
I'm looking to purchase another pair of DeMarchi bibs. FTR, I'm not interested in what others think I should purchase, only info related to their sizing. I've only worn their size large, which has worked out quite well, but I've lost some weight and their not as perfect as they once were. My concern is going to a medium is their size chart says medium is for a slim build while large is for a regular fit. I'm 5'7" (67cm) and 148-150 lbs. If anyone has any experience with the fit differences between medium and large, I'd appreciate the advice. Thanks.
Speedplay is the devil!
Bigger Gear
by Bigger Gear
Surely you would be M. I comfortably wear a L in DeMarchi bibs and I am 6' (183 cm), 165-170 lbs (76-77 kg). My waist is 32.5" (82.5 cm).
