Light versus heavy clincher ride/race performace/results
Your best ride/race with heavy/light clincher wheel set.
Flat ride/race (heavy clincher)
15%
Flat ride/race (light clincher)
4%
Hilly ride/race (heavy clincher)
12%
Hilly ride/race(light clincher)
12%
Mountain ride/race (heavy clincher)
4%
Mountain ride/race (light clincher)
23%
Time trial (heavy clincher)
8%
Time trial (light clincher)
No votes
Criterium (heavy clincher)
8%
Criterium (light clincher)
15%
Total votes: 26
el condor
by el condor
I was wondering how everyone feels the ride/race with a rather heavy clincher wheel set versus those fancy expensive light clincher wheel sets, no matter whether full carbon, carbon with alloy braking surfaces or aluminium ones. Please state the rim profile and explain what- for example, could be accounted for your impression.
I own a lot of wheel sets-all sorts, light and heavy including tubular, but let's stick to clincher for now, the reason I started this thread is the fact, if I look back at my 25 years of cycling-racing, I realise that my best performances using clincher wheels around 4 out of 5 or around 80%-happened when using rather heavy clinchers including mountain tt's. Wondering if some of you have a similar impression-experience/observation.
Please by using the poll use all five options by stating in the light or heavy section which one was the better/faster performing clincher wheel set.
Horze
by Horze
Heavy wheel will hold speed well due to inertia.
There are other psychological considerations. Lighter wheel will encourage rider to push possibly taking into red-zone. It takes longer to recovery out of it.
If grad is not so high you have more gain from a "heavy" wheel.
7x Forum Racing Ban Champion.
eric
by eric
The question is incomplete. If both wheel sets have the same aerodynamics, the light wheels will outperform the heavy wheels. If it's a level time trial the difference will be small. If it's an uphill race with a lot of surges (so both total weight up the hill and the cost to accellerate the wheels have an effect) the difference will be larger.
Also, performance depends on a lot of factors, many of which have much more effect than wheel weight.
Rick
by Rick
The light set beats the heavy set in every scenario,
el condor
by el condor
Rick wrote:The light set beats the heavy set in every scenario,
Light wheels-often more flex and to me often doesn't make me "feel" going fast, like not feeling the wheel.
tymon_tm
by tymon_tm
stiffness :idea:
i once found a 2-kg ~40mm deep bada$$ clinchers actually 'faster' than a DA WH-something low-profile CLs. in the hills. ok, maybe not alps, but 1-5 km ascents definitely hills i consider. and i weight somewhere around 65kg.
the inertia thing, yes but i assume it's rather the case with flat roads where speed is greater. i've owned and ridden some fancy wheelsets, but somehow 1,8 kg Cosmic Carbones are my all-time fav
kkibbler wrote: WW remembers.
BmanX
by BmanX
WRONG! A heavy aero set will beat a light non-aero set every time until you are going up a grade of 6% or greater for a long period of time. Outside of climbing for long periods of time the heavy more aero wheel set wins.
A set of FLO 60mm at 1961g will be faster than my 1300g EDGE45 wheels every single time until we go uphill.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
53x12
by 53x12
Maybe if it is the same rim design, just made from heavier material. However, as already noted, aero will trump weight in every scenario except for steep climbs. However you need to ride in the flats to get to the climb, then need to ride down the other side of the mountain. The best is if you can incorporate both aero and ww in the same wheelset. There are a few options if you want this.
BmanX
by BmanX
Aero and light is Always right. Something in clincher with latex tubes and maybe a 4000s tire and a wheelset around 1400-1500g and Zipp, hed, or Enve is best.
BIG DADDY B FLOW
53x12
by 53x12
I would personally go with tubulars instead, but that is just me. But a good quality clincher set also works.
