It is currently Fri Jan 19, 2018 2:55 pm
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Mon Aug 05, 2013 10:35 am
Last night on my way to a neighborhood convenience store to grab some beers, my front rim got caught in one of those sewage lids and I flew over the handlebar. Not sure how I managed to land on my feet but my new carbon rim is cratched up pretty bad.
While pretty pissed off, I can't help thinking sewage lids in several countries I have visited seem to have this sort of really annoying design. Since WW is a very international forum, which countries have more cyclist-accommodating sewage lid designs?
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
PostPosted: Mon Aug 05, 2013 11:01 am
In New Zealand probably 98% of them are like that. Some councils are progressively turning them 90 degrees as other work is done so they are less of a wheel trap. But they're incredibly rare.
The worst ones though have never been raised as layer after layer of new asphalt has been laid on the road surface next to them. So in a worst case scenario you have a six inch deep hole to fall down before your front wheel hits the grating.
Moral is don't ever ride in the gutter.
Nice bike... you ever take it off any sweet jumps?
2016 Canyon Ultimate CF SLX
2016 Cannondale Synapse Carbon
2016 Cannondale F-Si Carbon
PostPosted: Mon Aug 05, 2013 11:10 am
We have those in the UK but most tend to be at 90 degrees to the picture so wheels don't get caught, either that or they have a bar section in the middle to split the grill up so hopefully your wheel would get nudged out halfway rather than just get wedged in the full length of the grill like in the picture.
PostPosted: Mon Aug 05, 2013 11:21 am
I have discussed this matter with some urban engineers.
The reason why these are set up like on the photo is to get small twigs from trees plus leaves and other urban dirt into the sewage system when it starts to rain.
So these lid openings are set up in the direction of the water flow. O/wise the dirt does stuck easily in the lid and following leaves and other stuff will block the lid from taking road water in.
Was also informed that biker friendly set up lids will cause stress for people with a baby carriage crossing urban roads who will stuck with their wheels within the traffic.
Now the last design it good for both worlds.
The newest lid openings are X shaped.
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
PostPosted: Mon Aug 05, 2013 1:05 pm
I had the same thing happen a few years ago in California. I was on aluminum wheels, so luckily they only had to be rebuilt. Very dangerous.
Surprisingly, now I'm on the east coast and see less of them. Most of the ones here are rotated 90deg.
"Deserve's got nothing to do with it." William Munny
PostPosted: Mon Aug 05, 2013 2:00 pm
In the UK they're at a 45 degree angle so as to avoid trapping wheels coming across them and still face in to the flow of water.
PostPosted: Mon Aug 05, 2013 2:26 pm
Around here (Utah, USA) the grates seem to be designed so that bike wheels won't fall in from any angle.
Last year, however, I had my front wheel slip into an expansion crack in a section of concrete road and went down very hard at high speed. Usually the expansion cracks are less than 1" wide and have some sort of asphalt packing stuffed into them. I have gone over them hundreds of times. So I wasn't being cautious enough and tried to ride over this one that was exceptionally wide and unpacked. It was just wide enough to allow my from wheel to slip down in and hold it.
PostPosted: Mon Aug 05, 2013 2:51 pm
The answer here would be not to ride in the gutter. The 3 ft. rule applies.
PostPosted: Mon Aug 05, 2013 2:56 pm
Seattle area in the USA seems to be positions at the 90 degree mark. As for riding on them, I try not to no matter how they are oriented.
PostPosted: Mon Aug 05, 2013 5:28 pm
elviento, glad you're ok. Some in the US are at 45 degrees, but that didn't stop a horror story - a good friend bike shop owner left his shop at night, hopped off the curb and went straight into one of these 45 degree ones. Straight onto his face and almost died. Be careful out there.
PostPosted: Tue Aug 06, 2013 9:34 am
These things can indeed be dangerous. I cracked a wheel on a similar one to elviento's in taiwan. It was under a bridge, the transition from bright to darkness made me miss it. Here in belgium where I live they are narrow and 90 degrees angled.
PostPosted: Tue Aug 06, 2013 11:58 pm
That 45-degree example looks frightening in the rain.
Most in the US are perpendicular. The parallel (dangerous) orientation is specifically excluded in design manuals. That said, there are still examples, and people still get launched over bars.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Wed Aug 07, 2013 1:25 am
Shop Wrench
Most of the ones I ride past are grids, not slats. If I see a slatted one though, it's always parallel to the road.
PostPosted: Wed Aug 07, 2013 5:02 am
It was too dark that night so I totally didn't see the thing as I normally stay away from them. Maybe it's karma for getting beer so late at night. LOL
Maybe another reason for going wide rim/tire.
www.falcobike.com
PostPosted: Wed Aug 07, 2013 2:35 pm
That's what they do in my area as well as it's too expensive to raise the drain. Fortunately the drain slats are now mostly at right angles to direction of travel.
Good advice re. riding in the gutter and if you have to be ready to bunny hop.
There are no new unread posts for this topic. Di2 battery drainage / diagnostics tool
wheelsONfire
7
1265
Fri Apr 14, 2017 2:26 pm
wheelsONfire View the latest post
Users browsing this forum: Bing [Bot], nismosr, P90Puma and 12 guests
