It is currently Mon Jan 22, 2018 2:00 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Mon Jul 29, 2013 7:24 am
shot in the dark, but looking to get some advice regarding overall saddle height.
the measurement i'm looking for is from bottom of the rail, to the top of the nose.
the shorter this distance, the better. my seatpost tapers at the top and if i can reduce the saddle height so i can bring the seatpost up just a hair, i wont be forced to swap posts.
saddles im looking at are rolls, turbo, regal, flite, ie anything late 80s/early 90s style.
current saddle on the bike is a mundialita, and seems to be excessively spaced.
thanks
PostPosted: Mon Jul 29, 2013 5:16 pm
My Flite Ti, 2010 version, from bottom center of rail to top of saddle is 47mm +/- 1mm. My early 90s Flite Ti is more like 50mm at the center, because this saddle curves up more abruptly towards the rear. I don't know if the re-released "Flite 1990" has the same spec or not. I'm not sure why you want "bottom of the rail, to the top of the nose", a bit difficult for me to measure on the bikes. On my newer Flite I would say it's pretty close to the center-top measurement, because the top is fairly parallel to the rails. On the 1990 it's much shorter, in the 25mm range, because the nose on this design dips below a line drawn through the rails. In other words, to have the center to tip section of the saddle top reasonably level, the rails are actually tipped up about 10-15 degrees. If that makes sense? Here's the 1990 on wiggle http://www.wiggle.com/selle-italia-flit ... al-saddle/
I assume you're at the limit line on your seatpost?
PostPosted: Mon Jul 29, 2013 5:59 pm
Could you consider changing your subject to something more useful?
"do you know your saddles?" is a bit vague. I came into this half expecting to see a link to a 'saddle quiz' or something like that. Instead you want advice on similar saddles to something you have in mind.
If you change the subject to be a bit more specific, you may have a better response rate and be a bit more helpful to other people here. This is not an unreasonable request.
Thanks. :thumbup:
PostPosted: Mon Jul 29, 2013 6:43 pm
kbbpll, thanks for the info. I am not looking for an exact measurement, but maybe more a general consensus on what those with experience with the saddles believe to sit higher or lower. I am indeed at the limit, and i want to keep the campagnolo post thats currently on there. I need to shave maybe 15mm, and didnt think it was impossible given how high the current one is.
prendrfeu, a quiz would be a good idea! I will try and edit the title
PostPosted: Tue Jul 30, 2013 4:37 am
My 1980 Brooks is about 60mm at center of rails. It's probably hammocked somewhat; I put a lot of miles on it.
What does the mundialita measure? From pics online it looks pretty tall. And suede?!
PostPosted: Tue Jul 30, 2013 12:31 pm
The new Regale are not that high and have the older classic shape. Been on one all year, can't complain.
HUMP
Why are the best things in life always the ones you start last?
There are no new unread posts for this topic. Saddle height and agility
dedobike
16
1382
Sun Oct 15, 2017 1:40 pm
dedobike View the latest post
There are no new unread posts for this topic. Attachment(s) [EDITED] What are the most popular handlebars?
[ Go to page: 1 2 3 4 5 ]
Epic-o
67
7448
Fri Mar 10, 2017 8:38 am
Gazelleer View the latest post
There are no new unread posts for this topic. Lower back not letting me ride... Help!
in Training
zalle
18
1504
Tue Apr 18, 2017 8:49 pm
Rick View the latest post
There are no new unread posts for this topic. BMC teammachine lower bearing spec?
xcnick
Sun Nov 12, 2017 4:28 pm
xcnick View the latest post
There are no new unread posts for this topic. Chain falls off lower jockey wheel SRAM Red 22
octave
Sat Feb 04, 2017 9:06 am
Tom14 View the latest post
Users browsing this forum: No registered users and 5 guests
