Stolen - 2 x MTB - Turner/Specialized
Stoo
by Stoo
Stolen from Weston Favell area of Northampton, 1AM today (4th June '13)
Spec and a few piccies of the Turner
Frame: 2005/2006 Turner 5 spot (Last of the Horst Link) in Black, Size Large (19")
Good condition overall with a few light marks, paint chips and cable rub in the usual areas. No cracks or dents.
Decals are starting to get a little tatty
ALL Suspension Pivot bushings have been completely replaced and re-greased recently and only 10 dry miles rode since. The rear Horst pivots have also been upgraded to the larger bushings too to increase rear end stiffness.
FrontFork: RockShox Revelation 426 Dual Air U-Turn, Motion Control Pop-Loc
RearShock: Fox Float RP23, 120mm w/3 Stage ProPedal
Front fork has some cable rub and the decals are a little tatty but nothing to write home about.
Bar mounted Motion control Pop-loc currently missing.
Groupset: Shimano XTR
Brakeset: Shimano XTR M975 w/180/160mm Shimano 6 bolt rotors
Shift Levers: Shimano XTR M970 9 Speed with XTR Gear cables
Front Derailleur: Shimano XTR M971 Dual Pull 34.9mm
Rear Derailleur: Shimano XTR M971 SGS Long Cage
Slight marking from a very small off, does not affect performance
Crankset: Shimano XTR M970, 22/32/44T Chain rings
Slight rub to the crank arms from shoes but does not affect performance
Cassette: Shimano XTR M970 9 Speed 11-32T
Chain: Shimano XTR/Durace 7701 9 Speed
Brand new chain fitted approx 10 dry miles ago
Pedals:Crank Brothers Candy C titanium SPD
Bottom Bracket: Shimano XTR
Recently replaced
Hubs:Mavic Crossmax
Rims: Mavic Crossmax XL (Tubeless)
Hubs run free and rims run true, straight as a die! Stickers are slightly tatty
Tyres: Maxxis Ignitor XC
Seatpost: Easton EA70
Seatclamp: Hope QR in grey
Saddle: SDG Bel Air
Handlebars: Easton EC70 Monkey Lite XC Lo-Rise (Carbon)
Stem:Thomson Elite X4 90mm 0deg rise
Headset: Race Face Thermo SP w/Hope Head Doctor
Grips: ODI Ruffian LockOns (White)
Slightly grubby but only a few months old
ALSO STOLEN AT THE SAME TIME
Wifes 2012 Specialized Myka Sport Disc
Spec from spesh website
Medium frame
In black with red stripe
Fork
SR Suntour XCM
Chainset
SR Suntour, 44/32/24
Cassette
Shimano 9-speed, 11-34t
Chain
KMC X-9
Front Derailleur
Shimano Acera, 9-speed, 34.9mm clamp, top-swing, dual-pull
Rear Derailleur
Shimano Acera, 9-speed, SGS cage
Bakes
Tektro Draco hydraulic disc brake, post mount, 160mm 6-bolt rotor
Pedals
Composite platform
Handlebars
Alloy XC riser bar, 8º backsweep, 4º upsweep, 25.4mm
Stem
3D forged 6061 alloy, 4 bolt clamp, 10º rise, 25.4mm
Headset
1-1/8" threadless, loose ball w/ seals
Grips
Women's Myka, dual density Kraton
Saddle
Women's Body Geometry Riva, 155mm width
Seatpost
Alloy, 2 bolt head, 30.9mm, 12.5mm offset, micro adjust
Rims
Alex HR Disc 26"
Tyres
Specialized Fast Trak LK Sport
Shifters
Shimano Acera, 9-speed Rapidfire
ANY INFO PLEASE CONTACT ME ON 07500 873 883
Thanks
'18 Giant Trinity Pro TT - DA9070 - Rotor 3D+ P2Max - Zipp 900T/HED Jet 9+
'18 Giant TCR Advanced Pro 1 - R8000 - QuarQ DZero - SLR1
'16 Genesis Equilibrium - U6800 - FSA SRM - WH6800
'13 Giant Trinity Composite - U6800 - QuarQ DZero
paulm2322
by paulm2322
Sorry to hear that. Best of luck finding the scumbags.
You can't 'out train' a bad diet : )
Stoo
by Stoo
Thanks Paul.
No news yet :(
