Cycling Magazine Bike Weights
mellowJohnny
by mellowJohnny
I take just about everything I read in the bike press with a grain of salt, but I'm having a hard time swallowing some of the weights I've seen recently.
Bicycling ran their Editor's Choice issue and listed a 58cm "Cannondale SuperSix 3 Ultegra" at 15.2 lbs. Did they weigh it on the moon? Pretty sure my 56cm rolled out of the bike shop (also sans pedals) at a hair over 17 lbs. That's not a trivial difference.
So next time you read some wildly inaccurate weights, email them.
Tinea Pedis
by Tinea Pedis
Sounds crazy, but have you emailed the mag to try and clarify where the difference might have arisen?
mellowJohnny
by mellowJohnny
Yep. Kinda hypocritical if I didn't.
Really all I'm asking for is an effort to publish actual weights based on a sample in their possession, with enough detail (space permitting) to explain any possible variations. But this is a mid range stock bike, so I'm curious to see how they explain away a kilo...
Tinea Pedis
by Tinea Pedis
RIDE Mag, who I freelance for, strip and weigh every component of every bike that is reviewed. Regardless of if 3 bikes have the same groupset model or not, every bit is weighed and published.
Email Bicycling and ask them what their protocol is.
Getter
by Getter
Bicycling Magazine? Well...that's your answer.
mellowJohnny
by mellowJohnny
Tinea Pedis wrote:RIDE Mag, who I freelance for, strip and weigh every component of every bike that is reviewed. Regardless of if 3 bikes have the same groupset model or not, every bit is weighed and published.
Right, the proper way to do it. Cycling Plus does the same thing. We'll see what they say...
mellowJohnny
by mellowJohnny
Getter wrote:Bicycling Magazine? Well...that's your answer.
Christmas present from my sister...what can you do. :-)
Wingnut
by Wingnut
IMO RIDE magazine has the most credibility atm...they're very thorough...
"It's not the destination...it's the ride!"
mdeth1313
by mdeth1313
Bicycling will publish whatever the manufacturer tells them to. It's all about the advertising dollars they get. Could be one of the most misleading publications ever (outside of politics).
Speedplay is the devil!
thisisatest
by thisisatest
Bicycling is one of the worst magazines of any genre. You are actually better off staring at a blank tv screen for the same amount of time.
Sent from my EVO using Tapatalk 4 Beta
eric
by eric
Pretty sure their standard weight is without pedals.
They do sometimes have useful articles. But they are aimed at beginners to serious cycling, which leaves out most of the people here.
mellowJohnny
by mellowJohnny
Agreed - and mine without pedals weighed 17 lbs (give or take), not 15.
My point is simply that if you are going to publish the weight, weigh the bike. Alternatively don't publish the weights at all, I'd be fine with that too, and I'm sure so would most of their readership.
BTW, no response to my email yet...
djconnel
by djconnel
Bicycling magazine actually has some decent articles, but the bike reviews are meaningless.
Agree full bike weights are garbage. The wheels and tires, for example, play such a dominent role, and usually the differentiating feature of interest is the frame & fork. Even bar tape can be a bigger difference than the difference between frames.
