It is currently Thu Oct 19, 2017 7:30 pm
Post new topic  Reply to topic  [ 199 posts ]  Go to page Previous 16 7 8 9 1014 Next
PostPosted: Mon May 19, 2014 12:36 pm
Anyone have the long sleeve Gabba with removable sleeves?
Thinking of that option, over the short sleeve.
The Gram
The Men of Steel
PostPosted: Mon May 19, 2014 1:58 pm
I don't, but I am thinking of getting a short sleeve one to pair with some Nanoflex/NoRain arm warmers as the LS jersey arms really aren't as snug fitting as an arm warmer. Putting an aero cut jersey over the LS Gabba looks a bit off, especially if the jersey isn't black (mine isn't), so I see a SS one in the war chest in the near future.
PostPosted: Mon Jun 02, 2014 6:23 pm
That option is in my opinion the most versatile as it is warm in the winter and you use the Gabba also in weather conditions with a lot of wind without the warmers.
strava - youtube
PostPosted: Tue Jun 03, 2014 1:46 am
I live in San Francisco and my Gabba paired with arms Warner's is my go to kit for long weekend rides from fall to spring. That combo with a base layer works from the 50s to upper 60s
PostPosted: Fri Sep 26, 2014 12:33 pm
Bit of a bump, but it's getting cold and wet here. Not sure what size Gabba to buy, can anyone with a Small or Medium measure the width laid flat, from armpit to armpit? And maybe the width at the waist hem, since it tapers? Thanks!
PostPosted: Fri Sep 26, 2014 1:02 pm
Best thing is to try in a store or buy two sizes online and keep the one that fits best.
strava - youtube
PostPosted: Fri Sep 26, 2014 3:09 pm
Problem is in South Africa you don't get Castelli in the local bike shops. Which makes it almost impossible to buy online. :(
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
PostPosted: Fri Sep 26, 2014 3:40 pm
I've never tried another Castelli jersey other then the Gabba, but imo they are quite roomy. So if you are between sizes I would think the smaller option would be best.
Although don't take my word for it - I'm just comparing to the jerseys I normally wear, Rapha & Le coq sportif. All size large, the gabba aswell :lol:
PostPosted: Fri Sep 26, 2014 6:54 pm
I run small castelli and the Gabba has a bit more room in than compared to the regular castelli tops.
Have just measured my small Gabba (sleeveless version, the original one not the new "2")
Armpit to armpit is 49cm
Waist is 34cm
And just incase you wanted it the length the front from shoulder to hem is 54cm
PostPosted: Fri Sep 26, 2014 7:36 pm
Waist is 34cm
Thanks!
34cm seems quite small, it that because of elastic? Or maybe you meant to type 43?
PostPosted: Fri Sep 26, 2014 7:44 pm
its probably the elastic, it does stretch out a bit when you wear it unlike an aero jersey from Castelli
PostPosted: Sun Sep 28, 2014 1:28 pm
just measured my medium one, also original model, sleeveless
armpit-armpit is 56cm - laid flat, measuring to the lowest point at which the sleeve attaches
waist is 39cm
it's much stretchier at the waist than at the chest
fit is looser than a typical castelli jersey
PostPosted: Mon Sep 29, 2014 4:08 am
Hmm, thanks. Sounds like I need a Small. I have a Capo Lombardia in Medium that fits like a Small, thought Castelli would run smaller than Capo...
PostPosted: Mon Sep 29, 2014 6:47 am
Funny, I've had both at some point as well. Got M Capo and L Gabba which are the same sizes I have for other tops from those companies. L Gabba was just a bit too big in the chest and length. However, I got a Gabba vest as well in L and it fits much tighter, go figure. Capo fits perfect.
Ps fwiw I'm 39-40 inch chest, 180cm, 75kgs
PostPosted: Mon Sep 29, 2014 5:40 pm
For those whose Nanoflex or No-Rain garments have lost water repellency, throw them in the dryer or use a light iron. The water resistance comes right back. I talked to Steve Smith over at Castelli / Sportful about it and this is what he recommended.
On a related note, the Gabba v.2's are fantastic. Subtle changes to the cut make it even better. The Fawesome v.2 also has a Nanoflex Light back now so water resistance is even better. The new Sportful Fiandre stuff is pretty awesome too, especially the Fiandre Light No-Rain top. Basically like a Fawesome vest but with some Windstopper on the upper arms and some No-Rain Light on the forearms.
Being in rainy but mild Seattle, this stuff is gold.
There are no new unread posts for this topic. Gabba / Perfetto alternatives for cold weather riding.
nemeseri
11
1324
Mon Jun 19, 2017 6:59 am
Jju3jin View the latest post
There are no new unread posts for this topic. Castelli bib shorts: do they stretch with use?
nemeseri
12
1115
Thu Jun 29, 2017 1:39 pm
MattSoutherden View the latest post
There are no new unread posts for this topic. Castelli RS Superleggra sizing?
liam7020
Tue Apr 25, 2017 8:27 am
Tricky1 View the latest post
There are no new unread posts for this topic. Castelli Zipper -- RIP (no longer ZIP)
mdeth1313
10
1222
Tue Nov 01, 2016 2:06 am
mdeth1313 View the latest post
There are no new unread posts for this topic. Attachment(s) Rain jackets: 7mesh Oro vs. Castelli Idro vs. Gore One
vinuneuro
31
4499
Wed Mar 22, 2017 10:36 pm
nemeseri View the latest post
Users browsing this forum: campbellrae, Fiery, HammerTime2 and 13 guests
