Garmin Out-in-front Mounts Ad Nauseum
TonyM
by TonyM
Hamfist wrote:If you're outside the US you could always ask someone to get one for you and ship it to you. Just a thought....
the 2-3 months to wait was the info I received for Canada .... :cry: :cry:
TonyM
by TonyM
damond wrote:is there any mount that can be used with this stem?
thanks!
Maybe?
https://www.amazon.ca/dp/B00QT2WO84/ref ... 7FSOA1QK3Z
Hamfist
by Hamfist
I'm in Detroit so if you're in Windsor I could just toss it over the river.
TonyM
by TonyM
Thanks! No far away in Vancouver!
TonyM
by TonyM
K-Edge responded to my inquiry on the availability and they said end of November!
Tillquist
by Tillquist
Looking for a Garmin Out-Front mount ?
--->> http://edge-mount.bike
See all my bike h e r e
P90Puma
by P90Puma
Anyone else in Canada having trouble getting a K-Edge replacement insert for a Garmin?
hmai18
by hmai18
Use one of the parcel receiving services in Blaine/Point Roberts.
TonyM
by TonyM
Yes the way to go in many cases (we use Sumas as we are closer to it)
But now the Garmin mount for the Pro Vibe stem/ handlebar will be distributed from Shimano (as from January).
rkan
by rkan
Anybody tried this what is seemingly a new chinese one? Looks better than the previous one I linked ages ago, a bit heavy though. https://www.aliexpress.com/item/Bike-St ... 84192.html
edit: there's an another version with a gopro mount.. Might actually get one https://www.aliexpress.com/item/VGEBY-A ... 73895.html
edit2: nicely priced version with a gopro-light mount: https://www.aliexpress.com/item/3-in-1- ... 82963.html
edit3: if this is legit topeak RX mount, it is for a very nice price: https://www.aliexpress.com/item/Bicycle ... 87391.html
edit4... Here is what looks that could be very good for a handlebar mounted camera from a vibration point of view: https://www.aliexpress.com/item/Silvero ... 98507.html
Being directly under the handlebars could make the vibrations gain less "torque" from the mount itself..
Hamfist
by Hamfist
Anyone know which out front mount (Garmin) will work with an Enve aero carbon bar? I use a Pro stem so the Enve mount is out of the question. There's not a lot of room from the stem clamp to the part where the handlebar begins to flare.
WheresWaldo
by WheresWaldo
@rkan I am pretty sure on your edit 3 you only get the stem connecting parts not the Topeak mount itself.
slake21
by slake21
Hamfist wrote:
Thu Jan 25, 2018 5:35 pm
how about stem bolt mounts?
one of these should work
https://fetha.com.au
https://f3cycling.com
Hamfist
by Hamfist
Good ideas. On the Pro stem the faceplate bolts face the other direction. Any other ideas?
TonyM
by TonyM
Pre order:
http://edge-mount.bike/?product_cat=viber-di2
