MRM
by MRM on Tue Apr 25, 2017 11:25 pm
NiFTY wrote:I made a garmin mount for my TT out of 3mm carbon plate and some loose k edge garmin inserts. It mounts to the pro missile via the normal hardware. The exposure light mounts via another 1/4 turn adapter that I made. As a plus it stiffens up the front end. Currenty finishing a MCFK faceplate mount.
http://imgur.com/a/qc4nf
That is probably less aero than the typical regular option, but super badass! Looks like a throwback to the Space Invaders arcade game!
kode54
by kode54 on Wed Apr 26, 2017 3:07 pm
i ended up getting one as well. as nice as its made, now, i don't have a spot to put my Di2 junction box. i had it under the Garmin.
i'm still moving the arms out and trying that to see if it fits. i have a go pro mount under to clean up my light situation...that's what's getting in the way.
Powerful Pete on Mon May 01, 2017 11:51 pm, edited 1 time in total.
Reason: No need to quote the pic...
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Getter
by Getter on Fri Apr 28, 2017 11:53 pm
0rangesilk wrote:That looks pretty sweet. Is that a garmin 520 you are running? Was looking to maybe get one of these, do you have the short or long arms? I thought I should get the short arms but worried there wont be enough room to press the bottom buttons
It is a 520. I'm running the short arms. I still have more room on the arms to slide the mount farther out.
Only thing is that I had a heck of a time getting the mount straight. Even using some grease on the bolts and holding the arms as directed...the arms will still want to twist when tightening the bolts.
I did get an email for that recall. So far mine has been good. There is nothing to ship back. They are just going to send new inserts once they are done with production.
- Moderator
by Nefarious86 on Thu Jun 29, 2017 9:43 pm
Wish the Tillquist mounts had a gopro mount provision.
Anyone know the best solution for a 27mm wide stem mount that will accommodate an edge 1000 and a gopro mount?
Using Tapatalk
shuttlenote
by shuttlenote on Thu Jun 29, 2017 10:02 pm
Getter wrote:I grabbed one of the Form Mounts on their Kickstarter campaign. Took a few months...but it's a pretty nice piece of kit. Its modular so you can add different attachments to it.
[ig]http://i195.photobucket.com/albums/z14/RS_VR6/IMG_20170416_153958307_zpsgyiecidz.jpg[/img]
Had a helluva time aligning the two posts when tightening it down. I still think it is a bit uneven. How was your experience.
CLEAR
by CLEAR on Thu Jun 29, 2017 11:34 pm
Same here. Got few F3 form mounts. And on all 3 bikes (3 different stems, 3T arx, arxII, and zipp SL) hard to line up properly as the arms keep twisting. But very versatile nonetheless as it can be used on just about all horizontal bolts; bummer won't work on my MCFK and Vibe7s stems.
kode54
by kode54 on Sat Jul 01, 2017 7:26 pm
Tillquist wrote:Nefarious86 wrote:Any way to add a light Mount to the Tillquist ones?
I do not make this option
can't you make drillings to accept a KCNC go pro adapter? would fit on the metal bar under the Garmin mount. yes?
- Factor LS Disc
Tillquist
by Tillquist on Sun Jul 02, 2017 6:23 am
kode54 wrote:Tillquist wrote:Nefarious86 wrote:Any way to add a light Mount to the Tillquist ones?
Maybe [emoji4]
