Post new topic Reply to topic  [ 23 posts ]
Go to page 1, 2  Next
PostPosted: Wed Feb 06, 2013 9:53 pm
Hi all
I have just done some saddle adjustments with some measuring software and realised my saddle was to low so I have made some adjustments and was hoping someone could pass comment if it looks roughly right from the measurements ?
The measurements where taken when peddaling.
144crop by Tom_Hughes_87, on
144cropang by Tom_Hughes_87, on
Thanks in advance :)
PostPosted: Wed Feb 06, 2013 10:01 pm
I would say now it might be just a little too high. How much did you raise it from where you had it?
My Bikes
My Photoblog
PostPosted: Wed Feb 06, 2013 10:05 pm
Thanks for the reply, I put some tape where the original position was and its 20mm! My leg was at 133 deg before
PostPosted: Wed Feb 06, 2013 10:15 pm
If it too high its not by much though. I think my leg makes a similar angle to your now and I am sticking to it as its a comfortable postion.
www.thecycleclinic.co.uk
PostPosted: Wed Feb 06, 2013 10:29 pm
interestingly, according to this http://www.bikeradar.com/fitness/article/how-to-get-your-seat-height-right-14608/ you would be at the low end of the range in terms of height based on angle.
what is your saddle height from the BB to the top, as a percentage of your inseam?
dangerous curves ahead
PostPosted: Wed Feb 06, 2013 10:47 pm
Thanks for the replys,
Saddle height is now 72cm and my inseam is 79cm
PostPosted: Wed Feb 06, 2013 10:58 pm
I ride a 72, 72,5 lenght, for an inseam of 82 cm. FWIW. 70-80 mm setback from center of BB on a 74° seat tube (spot on Lemond or Guimard method).
Personnally, I couldn't ride comfortably higher than 72,5.
Louis :)
http://www.ccsalma.com
PostPosted: Wed Feb 06, 2013 11:03 pm
Thanks for the replys, Maybe I will put it back to how it was before and get a BG Fit as I dont want to be getting any injuries from poor setup!
PostPosted: Wed Feb 06, 2013 11:24 pm
sure you are measuring inseam correctly? ie with a narrowish book jammed tight under your crotch?
something's not jibing between the ratio and the angle you are measuring.
BTW and FWIW I read Greg Lemond's book back in the stone age and have been using the 88.3% rule since the early '90's.
In your case the formula would give a lower height of 70cm, but only if you were measuring correctly.
One formula will not fit all, but IMO it's a good starting point.
PostPosted: Wed Feb 06, 2013 11:32 pm
Just measured again with a slim book and got 80cm, would that make more sense? Thanks for the help much appreciated!
May sound daft but im assuming I measure bare footed against a wall?
PostPosted: Wed Feb 06, 2013 11:40 pm
you're getting warm.
the other important thing is to have someone follow you and check for any hip rocking which is a sure sign of being too high.
as you have seen, it's very important to do the measurements correctly.
my inclination would be to leave it as is, ride it that way and see how it feels, and check the hip rocking thing.
PostPosted: Wed Feb 06, 2013 11:46 pm
Thanks for the help, I have put it between what I started with and ended up with first to see how I get on so there isnt to much of a change
PostPosted: Thu Feb 07, 2013 3:25 am
Angles are irrelevant and merely coincidental. Seat height is dependent on more than an angle including pelvic stability, functional asymmetries, and other similar things that create an unstable pelvis and uneven pedal stroke.
I have always followed Hogg's method for setting seat height, which is a bit lower than what I've been fit at. When I check the angles they're fine, but I never used them to find the height because setback, bar height, and flexibility can also influence the angles
PostPosted: Thu Feb 07, 2013 3:32 am
I agree with KWalker. How stable are your hips? I think Steve Hogg recommends raising your seat in 3mm increments until your pelvis becomes unstable then lowering the seat 6mm. Like KWalker said functionality, saddle setback, cleat position, and bar position are all going to impact seat height and each other. Took me a lot of trial and error (still fine tuning) but right now I'm a fan of the Hogg method.
The only reason I know my seat height and other dimensions is so that I can transfer them to other bikes.
PostPosted: Thu Feb 07, 2013 4:20 am
Using Retul I can get the same knee opening with an 800mm seatheight and 110mm of setback, 770mm seat height and 95mm of setback, or 785mm seat height and 80mm of setback. All of these fit options are very, very different. FWIW I ride the last one and determined it through trial and error. Checked it with Retul and bam, it gives almost the same angles, but the cleats feel better, im more balanced, and have no hip rocking of any sort.
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
Users browsing this forum: nathanong87 and 6 guests
There are no new unread posts for this topic. LOOK 695 max seat height
DartanianX
Tue Dec 11, 2012 9:19 pm
OrPe View the latest post
There are no new unread posts for this topic. TT Seat Height and Fore/Aft + Tilt!!
KingWeenie
Mon Jan 28, 2013 4:56 am
kenpetruzzelli View the latest post
There are no new unread posts for this topic. Seat Height - Based on recent fitting
in Training
G6612
10
1554
Thu Oct 25, 2012 6:41 pm
juanacity View the latest post
There are no new unread posts for this topic. My WW build list - please critique!
RedRacer
39
1999
Thu Nov 08, 2012 9:10 pm
MDH View the latest post
There are no new unread posts for this topic. Attachment(s) my new r 440 new photos
hm123
Fri Jun 15, 2012 11:37 pm
prendrefeu View the latest post
It is currently Sat May 18, 2013 11:53 pm
