Post new topic Reply to topic  [ 23 posts ]
Go to page Previous  1, 2
PostPosted: Fri Jan 25, 2013 10:40 pm
Wing nuts? This is more than 2 decades after Campagnolo started selling QR's.
PostPosted: Sat Jan 26, 2013 2:53 pm
jekyll man wrote:
I think the 2 guys in the last pic will give as much of an answer as you're going to get on here ;-)
If you cant believe in what you think is right/wrong and what the shop is saying, try elsewhere..
i dont think pics on the turbo bear much resemblance to what happens out riding in regards to postion anyway, but i'm no expert
Yes I hear you, but I am so not a 56cm on paper its freaky.
Heart size 56, head says 54, wallet says different bike :shock:
PostPosted: Sat Jan 26, 2013 3:44 pm
I have a long torso with short legs. After decades of frustration I bit the bullet on a custom frame. Nothing is more important then fit for both perfomance and comfort. Save your coin until you can get a good fit. The picture you show is not a good fit IMO :beerchug:
WW Velocipedist Gargantuan
PostPosted: Sat Jan 26, 2013 4:10 pm
I knew a guy who went to the Merckx factory in Belgium and they had an old Chris Boardman frame: huge top tube to down tube delta, which they sold him off-the-rack.
The key issue here is we're used to pro teams where they squeeze the riders onto the standard range of geometries. As a result you end up seeing stuff like 16 cm stems in some cases. But if you compare different frame companies, as my plots show, you can find a range of fits. I'd look at Felt, for example.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Jan 31, 2013 9:36 pm
Short legs often means sizing down for a shorter HT length, switching out cone spacers and ordering a "Slam Your Stem" dust cover.
PostPosted: Mon Feb 04, 2013 3:38 pm
diegogarcia wrote:
Given we ride with our legs, I am now thinking 54cm for efficient pedal stroke as although chain stay length the same, extra 2cm stand over on 56cm = higher seat stays in turn affecting the saddle height and kops.
I'm sorry, but what are you talking about here? Seat tube angle is identical between 54 and 56, so why would your saddle position be changed? What does chain stay length or seat stay height have to do with your pedal stroke?
PostPosted: Tue Feb 05, 2013 3:24 pm
well the HT is taller, thus the top tube is taller, thus the seat stays are higher imo making the bike bigger at the back than a 54cm. Taller I would call it...?
PostPosted: Wed Feb 06, 2013 11:11 pm
So how's that going to change either your saddle height or setback relative to the BB?
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Users browsing this forum: Wookieopolis and 6 guests
There are no new unread posts for this topic. Long Legs Short Torso - what Giant TCR Advanced SL
Hillman
7
948
Mon Feb 11, 2013 1:22 am
yeagermeister View the latest post
There are no new unread posts for this topic. Short leg long torso, which frame size for Lynskey
freeloader
13
463
Tue Jan 01, 2013 8:39 pm
kya View the latest post
There are no new unread posts for this topic. wanted 40cm c-c sub 200g short reach drops
in Wanted
deermatt
Mon Apr 29, 2013 12:06 am
deermatt View the latest post
There are no new unread posts for this topic. Long reach brake pad holders
RollingGoat
Fri Jan 25, 2013 1:57 am
BobDopolina View the latest post
This topic is locked, you cannot edit posts or make further replies. Shaving Your Legs for Cycling
Geoff
Tue Jul 10, 2012 2:52 am
bricky21 View the latest post
It is currently Sun May 26, 2013 7:08 am
