Post new topic Reply to topic  [ 5 posts ]
PostPosted: Fri Jan 18, 2013 9:03 pm
Dura Ace 7900 pedals, SWorks shoe size 45 (about 11.5).
Even with the cleat all the way back the spindle is just under the ball of my foot. I want the spindle about 1 cm further back under my foot.
Anyone know any solutions? Can you re-drill these shoes? Modding the cleat doesn't seem possible.
Look pedal systems allowed much more flexibility in terms of cleat position and indeed I could get my foot significantly further forward on the pedal if I wanted. But the Shimano pedal is just a superior product. (Also I would never even consider a different shoe so that is out.)
Thanks.
swinter wrote:
Mr.Gib got it right
PostPosted: Fri Jan 18, 2013 9:13 pm
I'm interested as well since I have the same problem by a large margin with PI shoes. I asked here, but the only suggestions I could get were a bunch of uninformed recommendations to pay for access to Steve Hogg's site.
PostPosted: Sat Jan 19, 2013 2:58 am
I am using the S-works with 7900. I don't have that problem, but there is always the option of just drilling your shoes and using T-Nuts exactly wherre you need them. I have done that with other combinations.
Those with the big prongs are not ideal, but if you google there are many styles. The large flat head goes on the inside and is covered by your insole.
Extreme example:
PostPosted: Sat Jan 19, 2013 5:58 am
Excellent tip, thanks.
The prongs would have to be modified, ground down a bit.
I wonder about undermining the integrity of the sole. I think Specialized missed a bit with the larger sizes of their shoes. I have a normal foot and only at the most extreme rearward setting of the cleat would the set up be considered acceptable.
swinter wrote:
Mr.Gib got it right
PostPosted: Mon Jan 21, 2013 6:52 pm
Just for the record: I am in size 9, 42.5, and I thought I had fairly normal foot dimensions except a very high arch. I have my setup at pretty close to a KOPS position, and my cleats are just about centered in their adjustment range. I don't know if maybe you got a miss-drilled pair ? Can you compare at a LBS ?
Users browsing this forum: No registered users and 7 guests
This topic is locked, you cannot edit posts or make further replies. New Pedal and Shoe Set-up - Recommendations???
dehugo75
Tue Mar 12, 2013 10:40 pm
BdaGhisallo View the latest post
There are no new unread posts for this topic. Brand New 2013 Specialized S-works Road Shoe 44.5 (US 11)
NAKaveli
Fri Feb 22, 2013 1:01 am
NAKaveli View the latest post
There are no new unread posts for this topic. FS:Shimano R315 Shoe Shoes size 44 New in Box $200
boots2000
Sat Feb 09, 2013 11:56 pm
boots2000 View the latest post
There are no new unread posts for this topic. Fast Forward F6R Wheelset
Lafolie
7
2296
Fri Jun 15, 2012 3:48 am
joeyruan View the latest post
There are no new unread posts for this topic. BOR vs. Rotor 3D+ vs. Tune Smart Foot
Dammit
Mon Jul 30, 2012 9:15 am
LarsEjaas View the latest post
It is currently Thu May 23, 2013 12:34 am
