Post new topic Reply to topic  [ 8 posts ]
 Post subject: Head set cap
PostPosted: Mon Jan 14, 2013 1:50 pm
Other than the SLAM THAT STEM head set cap, does anyone know the part numbers for other smaller caps for the 2013 Cannondale CAAD 10? FSA, RITCHEY?
HUMP
Why are the best things in life always the ones you start last?
 Post subject: Re: Head set cap
PostPosted: Mon Jan 14, 2013 2:53 pm
HUMP
9mm cane creek is42 whether it's just the upper bearing assembly or the whole thing. , ebay all day, which is what i use. U can either just use the bearing cap itself or use it with the cane creek upper bearing. The lower bearing (if u buy the whole thing) doesn't work on caad10s.
i also have an fsa 8mm one that came on one of my caad10s, i can look it up tonight, that works fine and covers the headtube completely as well.
those are the only two that i know about.
PostPosted: Mon Jan 14, 2013 2:56 pm
Take a look and see if you have it. I will check out the Cane Creek one.
Thanks
HUMP
PostPosted: Mon Jan 14, 2013 3:34 pm
Use a lower angled stem? Specialized makes an adjustable stem via shims, but with +/- 0, 6, 8, 10, 17, 21, and 23 being out there, it shouldn't be too tough to make it work.
PostPosted: Mon Jan 14, 2013 5:48 pm
Veloflyte makes one. You can buy it from Fairwheel.
PostPosted: Tue Jan 15, 2013 3:19 pm
looked at the FSA cap and no number on it =\.
i can maybe edit this post tonight with a picture if u wanna send it to FSA or something, but honestly the cane creek is just as good (or the most available option)
PostPosted: Wed Jan 16, 2013 8:29 pm
Personal experience that Cane Creek i42 (the 40s series aka workhorse series) works just fine. I think I have tall in my parts bin ... pm if you are interested in the 15mm version.
PostPosted: Wed Jan 16, 2013 9:37 pm
FSA has an aluminum cap that is 6mm. "IS2" is stamped on the cap. There is a 15mm version of that cap too.
They come stock on some Cervelos.
eurperg wrote:
My wife is sitting next to me, and just thought that was a dildo, not a saddle.. :lol:
Users browsing this forum: jipperd and 8 guests
There are no new unread posts for this topic. Is it in my head or is there really that much difference?
wkend_warrior
Tue Aug 28, 2012 3:52 pm
sugarkane View the latest post
There are no new unread posts for this topic. Helmet for a round head.
campbellrae
30
1075
Tue Mar 19, 2013 8:23 am
1flytriguy View the latest post
There are no new unread posts for this topic. Head angles and steering?
BobSantini
Sat Nov 10, 2012 6:45 pm
Rick View the latest post
There are no new unread posts for this topic. Is the new Lezyne ABS pump head better?
spookyload
14
1166
Sat Oct 06, 2012 3:52 pm
djm View the latest post
There are no new unread posts for this topic. Top tubes and Head tube length.
MerckzFan
Sat Jan 12, 2013 8:12 pm
Geoff View the latest post
It is currently Thu May 23, 2013 1:11 pm
