Post new topic Reply to topic  [ 34 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Thu Dec 27, 2012 6:49 pm
I wish I could ride in snow right now. Too much snow here, roads are unsafe.
I am working on a 900m backyard singletrack at the moment, it needs a bit of work, I gotta make it wider and need to pack the snow harder before I can ride it. Loads of snow today here, gotta wait a bit more... meanwhile, ill shovel the driveway :S
2013 rocky mountain vertex 29er
­Twitter
www.cyclingtrainingnuts.blogspot.ca
PostPosted: Thu Dec 27, 2012 10:53 pm
You guys are crazy. I don't mind riding in bad weather, but with that kind of snow there's nicer things to do than cycling.
Bikes: Raceur, Beateur
PostPosted: Thu Dec 27, 2012 11:12 pm
just back from 1 hour ride with my 12 yr old son in the snow. He's on a multi gear Pugsley set up with grip shifters so he can wear heavier ( warmer ) gloves and still shift but he was again spinning out a bit with the stock endomorph tire on the rear. My singlespeed Pugsley has 2 Nates for grip so I might put my front on the back for him and replace my front with a Larry. Good times...
PostPosted: Thu Dec 27, 2012 11:25 pm
Not me in the pic but that's what we do here when the white stuff abounds. It makes the hardest ride seem easy lol.
PostPosted: Fri Dec 28, 2012 1:29 am
As someone whose country has very little snow and people fall all over themselves to get to it when we do, I'm amazed more of you don't ski?
Otherwise a friend who lives 'up north' swears by a 15-20 minute warm up on the rollers, half dressed. Then stepping off, final layers on, then heading out. Doesn't do it for much below zero, but work when it's at or just above freezing.
PostPosted: Fri Dec 28, 2012 1:41 am
Did most people not read this thread or the first post? :noidea:
It isn't about the OP finding it too cold.
It isn't about the OP not having other things to do in the winter.
In fact, most of the replies in this thread are very removed from the point of the thread, however valid and agreeable they might be.
The thread is about the OP complaining about their bike getting dirty when they ride.
That's it.
Exp001
PostPosted: Fri Dec 28, 2012 3:38 am
OP here. I'm following up on the fender suggestion. SKS Raceblades on order. Somehow I'd forgotten about fenders before I posted.
Saura mon coeur que mon cul poise.
adapted from Rabelais
PostPosted: Fri Dec 28, 2012 3:43 am
There ya go! :wink:
PostPosted: Fri Dec 28, 2012 5:21 am
I did.
If he ski's, bike stays clean :wink:
The second part was just some info other might find useful, maybe even the OP. Because if grime is already one reason not to ride, the temp could not be far off being the second :smartass:
PostPosted: Fri Dec 28, 2012 1:22 pm
Well, my winter bikes drivetrain if fully rusty after a training, we have very salty roads. Chain/casette does not last longer than a 2-3k Km, brake pads wear out very fast, aluminium silver colored rims corode and gets darker, sfifters sometimes gets frozen and does not work. Rubber on tyres gets hard and starts to crack. Pulley wheels sucks up dirt and must be replaced after a winter. I bought my winter bike with Deore for 150Eur and after one winter there is already half of the bike replaced. probably after this winter i will sell this bike for pennies and get new one for next winter.
Hydraulic brakes and air forks in winter is even worse.
PostPosted: Fri Dec 28, 2012 3:07 pm
Could you please describe the impact of winter conditions on hydraulic brakes? I don't recall that being mentioned in the threads debating their merits.
PostPosted: Fri Dec 28, 2012 3:15 pm
^^same problem here - salt
it's not just drivetrain that suffers, i had a magnesium merida once that after a winter literally broke near BB. so you either clean your bike after EVERY ride, which is painfull but it gets easier with time, and after you figure what and how to wash it takes ~10-15 mins. or you get a winter bike that you throw away after it's all squeaky and rusty
clothes suffer too - all this GORE stuff is great untill few laundrys = few rides. after that the material looses it's qualities significantly - it's not that a great deal if it's dry, but in wet, forget about 'waterproof' anything.
nonetheless, winter cycling is pure fun, my personal best is -20C with clear sunny sky and you really feel 'alive' after such ride. from my experience, even one hour in poor conditions with frozen feet is better (training wise) than half a day of indoor training. as a matter of fact, i dont use my trainer at all. it's a great bike stand for washing a bike though :idea:
PostPosted: Fri Dec 28, 2012 3:34 pm
Oil gets too thick, brake levers gets stuck. Probably you want some lower viscosity oil in brakes. At temperatures around 0 my hayes do work fine, but under -10 and hydraulic brakes just doesn't work. It's the same for fork, it gets slow and unresponsible.
PostPosted: Fri Dec 28, 2012 6:57 pm
never had any issues with my Hayes on my Pugsley no matter how low the temp and rigid-rigid serves me well so no fork issues either on road on off. Cleaning hasn't been an issue on road or off either perhaps because of the lack of shifters, derailleurs, cassette etc etc
PostPosted: Fri Dec 28, 2012 9:05 pm
Endomorphs suck regardless... I spin mine out occasionally on asphalt and other solid surfaces. The Nates will serve you well! I've been debating between those or some Husker Du's I think the HUDU's will work better in my climate.
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: TiG and 7 guests
There are no new unread posts for this topic. Tubular for Canadian spring riding (slush, dirt, sand, etc.)
LouisN
11
644
Wed Jan 02, 2013 8:37 pm
Geoff View the latest post
There are no new unread posts for this topic. Another C40 B-Stay
waynedude
Mon Feb 11, 2013 10:47 am
waynedude View the latest post
There are no new unread posts for this topic. Is the rise and hype of 52/36 compact here to stay?
aeroslave
32
4301
Wed May 30, 2012 1:54 pm
BikeTart View the latest post
There are no new unread posts for this topic. Shoe Heels Striking Chain stay
Horacio
16
1019
Mon Mar 18, 2013 8:57 am
User Name View the latest post
It is currently Wed May 22, 2013 2:46 am
