Post new topic Reply to topic  [ 38 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Wed Dec 12, 2012 6:03 am
If you actually care about getting your tire inflated, why a mini pump? A Topeak Road MasteBlaster does the best job. Stick it on your rear triangle (non-drive side) and you're good to go.
PostPosted: Wed Dec 12, 2012 7:22 am
Out on the road, lack of a pressure gauge is not a big deal. Assuming you didn't double-flat, pump until the flatted tire feels like the other one.
PostPosted: Wed Dec 12, 2012 2:18 pm
I use the Topeak race Rocket HP:
http://www.topeak.com/products/Pumps/racerocket_hp_sl
I don't think I can have a better pump right now IMHO.
I used to carry the Blackburn airstick, now it's in the bin...
Louis :)
http://www.ccsalma.com
PostPosted: Wed Dec 12, 2012 3:02 pm
+1000 for lezyne. i have a mini. dont think i've gotten up to 120psi with it because lack of caring to.... but it'll get up to 100psi for sure and CERTAINLY enough to ride home. not like i've raced with a mini pump in my pocket or anything.
-Nathan
PostPosted: Thu Dec 13, 2012 4:02 pm
I had a mini, and went to a large. The mini, although smaller is not unobtrusive, so I prefer the large.
waahila2 by pigmode, on Flickr
PostPosted: Thu Dec 13, 2012 10:34 pm
Thanks for the suggestion but as I have said earlier in this thread I couldn't possibly have a pump strapped to my frame, or have a bike bag for that matter. I'm far too vain. I have to have the pro look. My weekness I'm afraid.
PostPosted: Thu Dec 13, 2012 11:31 pm
I'd vote for this one http://www.topeak.com/products/Pumps/PocketRocket genuinely will get to 120psi.
Had it for a few years & would definitely buy it again if I lost it.
PostPosted: Fri Dec 14, 2012 12:59 am
Pros race without saddle bags, however most of them train with a saddle bag. Hence, get a saddle bag to mimic the pro look while training.
Storck Fenomalist 6.8kg
PostPosted: Fri Dec 14, 2012 6:09 pm
Wow -- extremely well stated. Deserves a bump.
The Lezyne is the best, I think, but be careful to make sure your valve core is tight before screwing on the pump head, then use the pressure-release button before removing it (as this seems to reduce the tendency to unscrew a removable core).
prendrefeu wrote:
let me continue that for you:
... and wasteful(1), and short-lasting (2), and costly(3), and limited(4)
So therefore mini-pump > C02 pump unless you're in a short (less than 100km) race w/o support.
Footnotes:
1. The amount of energy needed to create each cartridge, fill it with compressed air, ship it to your door all for one use is ridiculous. Only a very small percentage are actually ever recycled, the majority end up in landfills. Those that are recycled for metal content do not simply get re-filled: an entirely new cartridge has to be created for new sales, they are not re-used, along with all the energy needed to make that possible. Using compressed air cartridges is a bit of a 'f*ck you' to the planet when there are better, more intelligent resources available that are efficient, reusable, and longer lasting.
2. C02 leaves the tube faster than normal air mixture. Ever get a flat 100mi in with another 100mi to go? Your best bet is use a mini-pump or pray that someone has a floor pump in your near future.
3. Shit costs money, yo. One mini-pump = $45, years of use and no-limit to the amount of tubes it can pump up. Cartridges are a cost per use (and waste per use)
4. How many cartridges are you willing to carry on an extended ride? What if one releases gas through a poor valve connection? That's one less. A mini-pump is not limited in usage, and it's only one unit you have to carry - not a quantity of units.
Besides - use a mini-pump and give your arms a little exercise, eh? If you're properly fit and a well balanced athlete as you think you should be, getting a TopPeak Micro CF up to 120psi really isn't that big of a deal.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Dec 15, 2012 11:48 am
konky wrote:
Yes I liked prendrefeu's post also. I just ordered up a Lezyne carbon pressure drive 3 mini pump for £50. There is a limit on how much time one can ponder over a fairly basic item, and my limit is small.
Thanks for all the helpful comments
Good choice.
Don't let the truth get in the way of a good story......
Argon
CAAD9 6.78Kg
Supersix 6.78Kg
PostPosted: Sat Dec 15, 2012 11:16 pm
Online
Here's one example (lifting from another thread) - scroll down to see the bike:
https://twitter.com/HansenAdam/status/2 ... 84/photo/1
PostPosted: Sat Dec 15, 2012 11:54 pm
The Quicker Pro! I haven't seen it take less than top honors in the reviews that are out there. It soundly beats Topeak and Lezyne in comparisons.
http://www.quickex.com/200-143-quicker_pro.htm
http://swhs.home.xs4all.nl/fiets/tests/ ... ex_en.html
http://www.bentrideronline.com/?p=1957
http://road.cc/content/review/6815-quic ... -mini-pump
PostPosted: Mon Dec 17, 2012 2:54 am
Attaching a pump to a frame goes against the rules, just in case nobody knew yet...
PostPosted: Mon Dec 17, 2012 4:29 am
I had that Blackburn unt I lost it and couldn't get past 60psi without tearing the valve off. I now have a pro cnc+ and it's heavier but better. Has a hidden hose too.
Why not have the pump attached to the bottle cage, it doesn't look good? Weight. I know saddlebags look like shit.
PostPosted: Mon Dec 17, 2012 5:37 am
On the Topeaks my Mini-Morph seems to have given up on me. I tried swapping the O-ring and probably didn't get a perfect match and now it's worse. I should try to find a beefier O-ring. Or maybe something else is wrong. It just doesn't pump.
Fuji SL/1
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: HammerTime2, MisterNoChain, Routier, Sjoerd and 13 guests
There are no new unread posts for this topic. Most powerful road brake?
pletharoe
26
3116
Fri Jul 13, 2012 7:53 pm
Wolfshohl View the latest post
There are no new unread posts for this topic. Attachment(s) All I Want is a Pump That Works ...
Valbrona
35
2526
Mon Aug 27, 2012 9:33 am
mrfish View the latest post
There are no new unread posts for this topic. Is the new Lezyne ABS pump head better?
spookyload
14
1188
Sat Oct 06, 2012 3:52 pm
djm View the latest post
There are no new unread posts for this topic. Lightest shock pump?
in MTB
Jakomait
Thu Oct 18, 2012 11:20 am
TheRookie View the latest post
There are no new unread posts for this topic. Attachment(s) hand pump after a flat
project3
43
2272
Mon Mar 25, 2013 12:44 am
project3 View the latest post
It is currently Wed Jun 19, 2013 8:07 pm
