Post new topic Reply to topic  [ 38 posts ]
Go to page 1, 2, 3  Next
PostPosted: Tue Dec 11, 2012 11:46 am
I'm getting sick of ending up with 60psi or less in my tyres follwing a puncture and fitting a new inner tube on the road.
I want a new mini pump that can give me 80psi or more. Anyone tried the Lezyne micro floor drive mini pump? A tad bulky but should be OK for training. The mini floor pump idea might work well.
Or any other suggestions would be welcome. I may try a CO2 inflator which I've not tried before.
PostPosted: Tue Dec 11, 2012 11:53 am
I got a Lezyne mini last week. Good for 120 psi apparently.
http://www.torpedo7.com.au/products/L3PUMNNHVXX%20%20S
S-Works Venge
PostPosted: Tue Dec 11, 2012 3:42 pm
CO2 or a frame pump is the way to go
PostPosted: Tue Dec 11, 2012 4:17 pm
Please do a search on this forum it's been discussed extensively.
PostPosted: Tue Dec 11, 2012 4:22 pm
I am tempted by CO2. The Lzyne carbon road drive ABS looks nice but does it get you anywhere near 100psi? It claims 120psi.
Out of interest does anyone know if there is a difference between that pump and last years model the carbon drive 3 mini ABS pump?
I couldn't possibly have a pump attached to a bike. That's personal preference though.
(I did search 'mini pump' and there's not much in the last year)
PostPosted: Tue Dec 11, 2012 5:33 pm
The Blackburn Airstick will actually get you there. It will take about 300 pumps, but I have one and it works.
(I carry CO2 as the first line of defense.)
http://www.blackburndesign.com/pumps/ai ... MdgAuRIizk
PostPosted: Tue Dec 11, 2012 5:44 pm
viewtopic.php?f=3&t=30531&p=294929&hilit=lightest+mini+pump#p294929
viewtopic.php?t=26383&highlight=carbone
PostPosted: Tue Dec 11, 2012 5:55 pm
The Lezyne road model mini works quite well. Also less likely to damage the valve.
GRAVELBIKE.COM - ride everything
PostPosted: Tue Dec 11, 2012 6:08 pm
I use a tiny Airbone pump . Its less than 4inches long and works really well . Over 100psi.
http://www.airbone.com.tw/ZT702Product.htm
PostPosted: Tue Dec 11, 2012 6:25 pm
lezyne carbon road drive (medium) gets to 120psi ok
get the add-on pen gauge, you need to check it against a trusted pressure gauge to see how to read it as there're various possible interpretations, it can stick a bit, especially when new, tapping it sharply helps
only downside is the cf doesn't conduct heat well, so the metal end gets extremely hot, especially in summer
lezyne micro floor drive hp will also do 120psi, but is bulkier/heavier, again get the version with the pen gauge
in both cases the hose makes it easier to apply oomph to the pump without such a risk to valve/spokes if you slip
PostPosted: Tue Dec 11, 2012 9:14 pm
This is an easy one. Buy a good c02 system and a couple extra ones and practice at home so you are not surprised with you get a flat.
It's easy, quick, light, effortless, etc.....
PostPosted: Tue Dec 11, 2012 9:24 pm
let me continue that for you:
... and wasteful(1), and short-lasting (2), and costly(3), and limited(4)
So therefore mini-pump > C02 pump unless you're in a short (less than 100km) race w/o support.
Footnotes:
1. The amount of energy needed to create each cartridge, fill it with compressed air, ship it to your door all for one use is ridiculous. Only a very small percentage are actually ever recycled, the majority end up in landfills. Those that are recycled for metal content do not simply get re-filled: an entirely new cartridge has to be created for new sales, they are not re-used, along with all the energy needed to make that possible. Using compressed air cartridges is a bit of a 'f*ck you' to the planet when there are better, more intelligent resources available that are efficient, reusable, and longer lasting.
2. C02 leaves the tube faster than normal air mixture. Ever get a flat 100mi in with another 100mi to go? Your best bet is use a mini-pump or pray that someone has a floor pump in your near future.
3. Shit costs money, yo. One mini-pump = $45, years of use and no-limit to the amount of tubes it can pump up. Cartridges are a cost per use (and waste per use)
4. How many cartridges are you willing to carry on an extended ride? What if one releases gas through a poor valve connection? That's one less. A mini-pump is not limited in usage, and it's only one unit you have to carry - not a quantity of units.
Besides - use a mini-pump and give your arms a little exercise, eh? If you're properly fit and a well balanced athlete as you think you should be, getting a TopPeak Micro CF up to 120psi really isn't that big of a deal.
Exp001
PostPosted: Tue Dec 11, 2012 10:07 pm
I have a Lezyne minipump and it's the best minipump I've used. The hose between pump and valve does indeed isolate the valve from unintended heavyhandedness plus it means the entire length of the barrel can be used for pumping air. Bear in mind that any minipump needs a large number of strokes to get anywhere near 100psi so there is a slight upper body workout there. Accept minipumps as get-you-home devices, not workshop tools for prepping your bike to perfection.
(Good post above re CO2 cartridges!)
PostPosted: Tue Dec 11, 2012 10:53 pm
Yes I liked prendrefeu's post also. I just ordered up a Lezyne carbon pressure drive 3 mini pump for £50. There is a limit on how much time one can ponder over a fairly basic item, and my limit is small.
Thanks for all the helpful comments
PostPosted: Wed Dec 12, 2012 5:27 am
I also added this to my Lezyne pump. I guess I'm fussy, I like to know my pressure:
http://www.artscyclery.com/Lezyne_Pen_Gauge/descpage-LZPENGUAGE2.html?crumb=RDMACCESS
Scott
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: genesis692 and 8 guests
There are no new unread posts for this topic. Most powerful road brake?
pletharoe
26
3115
Fri Jul 13, 2012 7:53 pm
Wolfshohl View the latest post
There are no new unread posts for this topic. Attachment(s) All I Want is a Pump That Works ...
Valbrona
35
2522
Mon Aug 27, 2012 9:33 am
mrfish View the latest post
There are no new unread posts for this topic. Is the new Lezyne ABS pump head better?
spookyload
14
1187
Sat Oct 06, 2012 3:52 pm
djm View the latest post
There are no new unread posts for this topic. Lightest shock pump?
in MTB
Jakomait
Thu Oct 18, 2012 11:20 am
TheRookie View the latest post
There are no new unread posts for this topic. Attachment(s) hand pump after a flat
project3
43
2269
Mon Mar 25, 2013 12:44 am
project3 View the latest post
It is currently Wed Jun 19, 2013 1:42 am
