Post new topic Reply to topic  [ 4 posts ]
 Post subject: Grease on Freehub?
PostPosted: Sun Dec 09, 2012 7:13 pm
I've always applied a thin coat of grease on the freehub prior to installing the cogs. Been doing that for 18 years as part of the wheel assembly routine after cleaning the cogs. Considering that the locking ring is torqued 45nm, there really is zero movement of the cogs within the freehub. I'm now thinking that the thin layer of grease only attracts dust particles in the freehub assembly and has no other benefit. Just curious to know what others do. TIA.
 Post subject: Re: Grease on Freehub?
PostPosted: Sun Dec 09, 2012 8:04 pm
i've never used any grease there
the parts aren't moving wrt to each other and there's nothing threaded to bind, so, as you say, it just seems likely to cause dirt to stick
i do put some antiseize on the lockring threads though
PostPosted: Sun Dec 09, 2012 8:45 pm
If I lived by the ocean, I'd consider it. Otherwise, it just makes a mess.
PostPosted: Sun Dec 09, 2012 9:00 pm
Thanks!
Users browsing this forum: fiti, Google [Bot] and 11 guests
There are no new unread posts for this topic. Best Hub Ratchet and Freehub Pawl grease
[ Go to page: 1, 2, 3, 4, 5 ]
KLabs
70
2516
Wed Apr 10, 2013 2:52 pm
KLabs View the latest post
There are no new unread posts for this topic. Groupset mounting bolts... to grease, or not to grease?
Stats
Tue Dec 25, 2012 12:09 am
yourdaguy View the latest post
There are no new unread posts for this topic. Campy UT Crank Cult Bearings - Replace or just re-grease.
JWolf
10
661
Sat Aug 04, 2012 9:03 am
Mattias Hellöre View the latest post
There are no new unread posts for this topic. ti anti sieze grease required for ti bolts on alloy stem?
in MTB
nrsnow
7
906
Tue Oct 09, 2012 12:44 pm
miceden View the latest post
There are no new unread posts for this topic. Shimano 10s vs 11s freehub compatibility.
expan
Thu Apr 11, 2013 6:24 am
Dalai View the latest post
cron
It is currently Sat May 25, 2013 10:08 am
