Post new topic Reply to topic  [ 24 posts ]
Go to page Previous  1, 2
PostPosted: Wed Nov 21, 2012 2:41 am
Post a pic of pro cycling and instantly validate your point. I like it.
Someone find me a pic of a pro on a triple crankset.
PostPosted: Wed Nov 21, 2012 2:15 pm
Not just any pro. A pro that nobody would accuse of sucking at climbing.
I'm just saying that you don't necessarily suck at climbing because you use a smaller gear than 39/28.
PostPosted: Wed Nov 21, 2012 5:27 pm
FWIW; I pretty much need a 28 for a five hour training ride in the mountains but hate the 11-28 on fast group rides or races. Gaps are too big, often find myself between gears. 11-25 tends to work out better in those situations.
PostPosted: Wed Nov 21, 2012 6:07 pm
I think a couple of people have mentioned the unwelcome wider gaps of the 11-28. Every choice has a compromise but doesn't the 11-28 represent a small one. How often does one get into a larger than 21 cog unless climbing something pretty nasty, when a 28 would come in handy.
PostPosted: Wed Nov 21, 2012 6:51 pm
Terrain around here is hilly and during a fast group ride, I like to keep it in the big ring. 11-25 works better for me in those situations.
You need to experiment and find what works best for you. No right answer for everyone.
PostPosted: Wed Nov 21, 2012 7:23 pm
I get you. In the big ring it would make a difference. I wasn't thinking. I like to use the big ring with the large cogs as well. Of course technically you can find the same gear without the crossover but sometimes it's easier to find the chosen gear and stay in the big ring. It feels different too.
PostPosted: Thu Nov 22, 2012 1:59 pm
I'm not accusing any pros of sucking at climbing. If alp d'huez is your weekly climb then by all means gear the hell out of it. Otherwise I maintain my stance, if you need more than 34x28 for your weekly climb, you suck at climbing. Addendum: if you need more than 39x28, you should be riding a compact crankset.
PostPosted: Fri Nov 23, 2012 10:50 am
Is there anything to stop you doing a mix and match here?
By that I mean, I've just bought a 11-28 to replace my worn 11-25 (both Ultegra 6700) as I have some big sportives coming up in the Summer. I don't really use the 23 and 25 that much in normal riding so would assume the 3 joined cogs (21,23,25) have not worn as much as the bulk of the block on the old cassette.
Assuming that is the case and these 3 cogs mesh well with the new chain and new cassette parts, is there anything to stop me using that cluster of 3 with the rest of the new Ultegra cassette and just switching in the 21,24,28 as and when needed or will there be problems with wear rates across the cogs and chain that would introduce skipping if the 21,24,28 weren't used all that often (new cogs, old chain say)?
PostPosted: Fri Nov 23, 2012 10:57 am
That's an interesting idea, matty. I think you can just check alignment of 21t cog and splines between the two clusters and it is the same, you should be safe mixing and matching them. However, if it is not, you'll likely have issues with shifting.
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Users browsing this forum: No registered users and 8 guests
There are no new unread posts for this topic. 11-32 cassette only new Ultegra??
FHKJ
10
841
Thu May 02, 2013 7:26 am
maxxevv View the latest post
There are no new unread posts for this topic. Sram XX 11-32 cassette
in Wanted
Sisbud
Sat Mar 30, 2013 12:32 am
Sisbud View the latest post
There are no new unread posts for this topic. WTT: 11-23 SRAM Red cassette for 11-26, 27 or 28
in Wanted
capnc
Wed Mar 27, 2013 2:38 pm
capnc View the latest post
There are no new unread posts for this topic. VO Hi-Low Cassette Rear Hub
WinterRider
Wed Mar 06, 2013 4:42 pm
MileHighMark View the latest post
This topic is locked, you cannot edit posts or make further replies. 7900 DA Cassette Q
sfo423
Sun Mar 17, 2013 6:09 am
kulivontot View the latest post
It is currently Sat May 25, 2013 1:02 am
