Post new topic Reply to topic  [ 4 posts ]
PostPosted: Fri Oct 19, 2012 1:30 am
Got a set of cheap carbon clincher wheels off ebay,60 mm deep on lovely silky smooth alloy hubs,Weighed 1715g for the pair.Spinning them by hand I felt a heavy spot,which turned out to be exactly where the hole for the valve is.But on the 1st couple of rides they felt great on the bike,at least a 1km improvement on my avg speed over a 50km familiar flatish route.Then I went up a local hillclimb,my best on my lighter weight alloys is 7.56 min,and I did a 8.05 mins,so I was very happy with that,as these new carbon rims are 235g heavier.However on the downhill,once above 55km per hour,the weight inbalance made the bike dangerous,so I had to keep the speed below 50kph.
So today,with bluetack and metal nuts I balanced out my carbon clinchers.It took 20g of added weight directly opposite the valve hole to balance the both wheels.Then I went to my local, friendly,car tyre garage and got 4 X 10g sticky tyre weights.Stuck 2 each of the lead weights either side off the rim opp the valve to balance out the wheels.I made sure the added weights did'nt hit the brake blocks/caliper arms.
Took the bike for a 55kph blast down the nearest hill and no vibration's,so problem cured!!Only bad bit is as a weightweenie,it sucks having to add 40g to my wheelset!!!! :(
PostPosted: Fri Oct 19, 2012 3:36 am
Some more expensive wheels have similar feature.
http://demarere.blogspot.com/" onclick="window.open(this.href);return false;
PostPosted: Fri Oct 19, 2012 8:36 am
Yeah its pretty common for wheels to have an imbalanced hop in them. Look at Fulcrum wheels what use heavier spokes opposite the valve hole for example.
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Sat Oct 20, 2012 1:42 am
My Reynolds carbon clinchers have a heavy spot at the valve too. Actually all my wheels, carbon or not, have a heavy spot. But the deeper rims use a taller valve stem which makes for a more unbalanced rim.
I have not added weight (sacrilege!) to balance any of my wheels, and I've never noticed the unbalance even at over 50 mph. The only place I notice it is when the bike is on the workstand.
I wonder if using tubes with short valve stems and aluminium extensions would be lighter than the long brass valve stem?
Users browsing this forum: HammerTime2, mentok, MSN [Bot] and 10 guests
There are no new unread posts for this topic. deepest chinese carbon rim
mrlogan
Thu Dec 13, 2012 9:27 am
bura View the latest post
There are no new unread posts for this topic. ebay chinese carbon frame
in Cyclocross / Touring
trickydisco78
19
4256
Mon Nov 05, 2012 4:28 pm
bc sparks View the latest post
There are no new unread posts for this topic. Cheap carbon fork 1 1/8 - Alu or Carbon steerer.
in Wanted
Megaclocker
Fri Feb 01, 2013 5:51 pm
Megaclocker View the latest post
There are no new unread posts for this topic. Nashbar Carbon frameset, Udi2, carbon clinchers, NOW W/PICS!
xnavalav8r
23
2663
Sun Apr 14, 2013 7:59 am
xnavalav8r View the latest post
There are no new unread posts for this topic. Pitch based carbon fibre the key to carbon clinchers?
in Everything wheels
Maximilian
Mon Apr 15, 2013 11:46 am
davidalone View the latest post
It is currently Sun May 19, 2013 2:18 am
