Post new topic Reply to topic  [ 31 posts ]
Go to page Previous  1, 2, 3  Next
 Post subject: Re: Winter Baselayer
PostPosted: Wed Oct 17, 2012 1:44 pm
have used Craft in the past and still use it, but less often than Rapha Merino or Assos base layers. the Rapha Merino base layers are much less fitting than the Assos base layers in the same size (M). so depending on what i'm wearing on top, i'll use what's best. any Merino is soft and comfortable...but since it fits me looser, the Assos tends to keep me much warmer. right now, its the fall interactive base layer that i wear the most. i also have the winter one as well...and can fit something tighter underneath since its roomier.
- Storck Fenomalist + Campy SR11 + Enve 45
- Parlee Z5 SL + DA7900 + Enve 3.4
PostPosted: Wed Oct 17, 2012 3:09 pm
http://www.Torm.cc! Only SS available, though I believe they are planning on LS at some point (which should be now to be of any use really)
PostPosted: Wed Oct 17, 2012 4:17 pm
The Rapha merino base layers are awesome.
PostPosted: Thu Oct 18, 2012 3:40 am
Any good quality Merino base layer is the way to go. Just make sure if its not cycling-specific that it will be long enough in the back.
Fear is healthy, panic can be deadly
PostPosted: Thu Oct 18, 2012 10:12 am
a friend talked me into purchasing an Icebreaker LS baselayer ...hope it was a good purchase :D
PostPosted: Thu Oct 18, 2012 1:19 pm
I have Craft Zero and Craft Zero Extreme baselayers and Rapha Merinos too.
The Merino is warm and comfy, the Craft Zero too.
The Zero Extreme is thinner and wicks very well. It almost cools.
Problem is, for me (I sweat a lot!), even the west wicking (Zero Extreme) is still not enough.
I get wet sooner or later and then get a cold...
Do you know any super wicking baselayers?
c*
PostPosted: Thu Oct 18, 2012 1:49 pm
cazone, this is a long shot, but what are you wearing on top? Often allowing for controlled circulation helps to get rid of the moisture, so sometimes less is more.
Bikes: Raceur, Beateur
PostPosted: Thu Oct 18, 2012 2:23 pm
I have 2 craft ones for winter. Had them for years so I could not tell you what they are called. One is just a heavy base but very for fitting and I love the high neck. The other one I have is basically the same base but it has a wind front panel. I only use it a few times a year (not too cold here in (So Cal) but when I do use it I am damn happy I have it!!
PostPosted: Fri Oct 19, 2012 5:44 am
They are terrific- I used them this summer (their winter) on a high altitude trip in Bolivia.
PostPosted: Fri Oct 19, 2012 10:28 am
BaaBaa all the way - I have more expensive merino base layers (eg Icebreaker) and the BaaBaa is just better (and much less expensive).
PostPosted: Fri Oct 19, 2012 11:22 am
managed to purchase the icebreaker cheap so that was a major factor in the purchase....for what its worth i sent an email to Torm.. and they are not bringing a LS Baselayer out this year/ season
PostPosted: Fri Oct 19, 2012 4:11 pm
Planet x merino ones are good, they do a really nice ultra thin one I am really like.
PostPosted: Fri Oct 19, 2012 4:52 pm
craft extreme LS or cold days. Craft warm for really cold days.
PostPosted: Fri Oct 19, 2012 9:19 pm
c*
From my experience it is the outer layer that determines whether you stay wet or not. The moisture has to either escape or keep building up. When I moved to a light/mid weight outer jacket with wind stopper material on the front (chest and stomach), front of the arms and shoulders but with with open knit back, sides and back of arms I've stayed dry no matter if I use a cheap poly base layer from Target or an expensive one by Craft. Or a combination of both depending on temperature.
"Really fast people are frustrating, but they make you faster. When you get faster, you might frustrate someone else."
2009 Trek Madone 5.5 Project One SRAM Force 16.4 lbs w/pedals and cages.
2007 Bianchi 928 Carbon Lugged- SRAM Rival-17 lbs.
PostPosted: Sat Oct 20, 2012 10:48 am
Castelli are great for this
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: Google Adsense [Bot] and 8 guests
There are no new unread posts for this topic. Winter wear
Monkeyboy3333
Mon Jul 23, 2012 8:20 pm
Monkeyboy3333 View the latest post
There are no new unread posts for this topic. What to upgrade this winter
russianbear
Wed Oct 10, 2012 9:24 pm
Zen Cyclery View the latest post
There are no new unread posts for this topic. Winter bike
DarkWing
Wed Oct 31, 2012 12:04 pm
adrien de la touche View the latest post
There are no new unread posts for this topic. My winter bike
markyboy
9
1544
Tue Oct 09, 2012 4:35 am
markyboy View the latest post
There are no new unread posts for this topic. Winter Build
in MTB
trialsntrails
Sun Jul 22, 2012 12:39 am
It is currently Sat May 25, 2013 6:26 am
