Post new topic Reply to topic  [ 9 posts ]
PostPosted: Sat Oct 06, 2012 6:24 am
Hi,
My girlfriend's height is 5'3 and I've found a 2009 Bianchi Via Nirone 44cm for sale for $450. Is this frame too small for her?
Also, is this a good price for this bike?
PostPosted: Sat Oct 06, 2012 6:46 pm
Look up the geometry chart on that ten go to a sizing calculator. I think that's the smallest size they make. TT could be 51cm and seat tube 44cm but check it out first. I think it might fit.
PostPosted: Tue Oct 09, 2012 12:03 pm
vickan240sx wrote:
Hi,
No way to tell from that info. Frame sizing involves many factors outside of height.
PostPosted: Thu Oct 25, 2012 3:06 am
I would bust out some measuring tools and figure out what is appropriate. 5'3" isn't enough information since she could have a long torso/short legs, short torso/long legs, long/short arms, etc. I know the cost of a fit session might be a bit much, but if you have any contacts that do such things I would recommend it, even if it is a simpler version of what they can do. Good luck!
PostPosted: Thu Oct 25, 2012 4:50 am
So, what we're saying, is send photgraphs and measurements. Of your cycling girlfriend. Doesn't sound questionable at all...
2011 Scott Addict R3 (DA groupset, Tune Skyline RR wheelset, Rotor 52/36 Q-Rings)
2008 Giant Trinity A1 (cheapass 50mm carbon clinchers)
No easy road goes anywhere worth going
PostPosted: Thu Oct 25, 2012 11:38 am
5'3 seems tall for a 44cm women's frame (from the little i know about womens frames, but have searched the jamis xenith and amira for a friend who is 4'11)
PostPosted: Thu Oct 25, 2012 12:36 pm
vickan240sx wrote:
Hi,
Yes, no, maybe... and all 3 could be correct. Here's the problem... height is a very poor indicator for bike fitting. You can have 5 people of exactly the same height, one fitting brand A/model A, the second can fit brand A, but not model A of the same size, the third, can't fit brand A/model A at all, but model B works fine, the 4th fits brand A/model A but needs one size up, and the 5th can't fit well on any of brand A bikes...
If you start adding what's included in a bike fit, it all makes sense... overall height is rarely measured as it's not relevant, but you will have lower leg length, upper leg length, upper body length, arm length, flexibility, core strength and then also all external factors, type of rider, distances riding/racing, terrain, athletic background, current/previous injuries/issues... that's why you can have two very different fits for two people of exactly the same height...
PostPosted: Thu Oct 25, 2012 3:05 pm
^ the above is true, but u can make some* generalizations in trends that most 6ft riders aren't using 52cm framsets...
PostPosted: Thu Oct 25, 2012 9:56 pm
Actually, not even that.... it *could* be situations where a 6' rider will indeed be fitted to a 52cm frame... it all depends on how the manufacturer denominate the size and how that is measured.... for example... let's say that Parlee decided to denominate their XL 52cm (which is the actual seat tube length), then you could argue that it could be called a 52cm and I bet that frame would be very likely to fit someone 6'...
http://www.parleecycles.com/z5-geometry/
Users browsing this forum: cydonian74, Google [Bot] and 7 guests
There are no new unread posts for this topic. FS: 2009 Bianchi Mono-Q Calfee Di2 conversion frame and fork
mlchang
Tue Apr 23, 2013 5:16 am
mlchang View the latest post
There are no new unread posts for this topic. Attachment(s) Pinarello Dogma 60.1 Frameset 44cm $2500
madcow
Tue Apr 23, 2013 4:36 pm
madcow View the latest post
There are no new unread posts for this topic. SRAM Red RD and small cog help
styrrell
Tue Mar 26, 2013 3:37 pm
indigo View the latest post
There are no new unread posts for this topic. Attachment(s) Let's see your small bikes...
CarpetFibre
33
4811
Sun Dec 16, 2012 2:33 am
pocketbeagle View the latest post
It is currently Thu May 23, 2013 12:43 pm
