Post new topic Reply to topic  [ 10 posts ]
PostPosted: Thu Oct 04, 2012 12:33 am
I noticed that specialized.com no longer lists 130 width saddles. I thought it was a stock issue but they list others as out of stock. Anyone have any info about this? I was looking for a Romin EVO in 130 but no luck.
PostPosted: Thu Oct 04, 2012 3:11 am
The population in our country has a bell curve that has shifted towards "fatter and wider", making the market niche for 130mm less marketable. :?:
Exp001
PostPosted: Thu Oct 04, 2012 3:18 am
The Romin actually is effectively narrower than the measurements indicate. A 143 is close to a 130 than 143, which is why they've brought out the 165. Look at it from the front and check out the curvature on the wings. Its much steeper than on something like a Toupe or Arione.
PostPosted: Thu Oct 04, 2012 4:49 am
Body fat shouldn't affect the seat bones? Also, if you have big legs, wider saddle will literally become a pain in the a$$.
http://demarere.blogspot.com/" onclick="window.open(this.href);return false;
PostPosted: Thu Oct 04, 2012 7:29 pm
Exactly! I can't ride anything less than 143mm and only weigh 150lbs. Weight has very little to do with how wide your saddle should be.
PostPosted: Thu Oct 04, 2012 7:33 pm
Maybe a fatter population also has wider sit bones (bodies growing in ways to accomodate the excess mass). :?:
and yes, these :?: are just exploratory comments.
Exp001
PostPosted: Thu Oct 04, 2012 11:13 pm
I bought a 130mm Toupe Pro 6 weeks ago.
If they stop making 130mm saddles I'll be in trouble!
You could be seeing just what's in stock for direct web sales. They seem to be pretty bad at web sales. Try a dealer.
PostPosted: Fri Oct 05, 2012 2:17 pm
That's odd... I see 130mm Toupe on the specialized site, and a 130mm Romin Pro as well. I don't see the a 130mm for the S-Works Romin.
S Works Romin Sizes
•Size 143mm/ Weight 158g
•Size 155mm/ Weight 165g
•Size 168mm/ Weight 173g
Romin Pro
•Size 130mm/ Weight 153g
•Size 143mm/ Weight 160g
•Size 155mm/ Weight 167g
Romin Expert
•Size 130mm/ Weight 199g
•Size 143mm/ Weight 205g
•Size 155mm/ Weight 212g
•Size 168mm/ Weight 219g
S-Works Toupe
•Size 130mm/ Weight 113g
•Size 143mm/ Weight 115g
Toupe Pro
•Size 130mm/ Weight 154g
•Size 143mm/ Weight 159g
PostPosted: Fri Oct 05, 2012 2:56 pm
i see that now too, i dont think i missed it but its still odd they have certain saddles in that size and not others. On a side note its quite annoying how they post new saddles on there way before they are released and just list them as out of stock with no other info.
PostPosted: Sat Oct 06, 2012 3:37 am
... <deleted>
r o y g b i v
Users browsing this forum: Craigagogo and 12 guests
There are no new unread posts for this topic. Saddles, saddles and more saddles...
Simon BP
Tue Mar 12, 2013 2:22 pm
Simon BP View the latest post
There are no new unread posts for this topic. Prologo saddles
skiezo
11
679
Sun Feb 24, 2013 4:31 am
russianbear View the latest post
There are no new unread posts for this topic. SMP saddles - thoughts?
G6612
26
1553
Thu Feb 21, 2013 10:11 pm
Kjetil View the latest post
There are no new unread posts for this topic. FS: Saddles (PRICE REDUCTIONS)
dcl10
Wed Feb 06, 2013 11:14 pm
dcl10 View the latest post
There are no new unread posts for this topic. Saddles and Oakleys $100 your pick!
hasbeen
Wed Feb 20, 2013 4:20 pm
hasbeen View the latest post
It is currently Wed May 22, 2013 2:26 am
