Post new topic Reply to topic  [ 15 posts ]
PostPosted: Mon Sep 17, 2012 7:44 pm
I love my Lezyne pump. Saddly it unthreads my valve cores on my XC wheels. Did the new ABS valve head fix the problem with this? Hope so because the concept is good, but constantly putting the valve cores back in is a PITA.
PostPosted: Mon Sep 17, 2012 9:41 pm
I've only used it a couple of times with valve cores and it's worked fine. I do make sure that cores are screwed in tightly to start with. The pressure release valve definitely seems to be a good idea.
BTW I've only used it on road tyres.
PostPosted: Mon Sep 17, 2012 10:16 pm
I have yet to unscrew a valve core since I bought it - before it would do it to at least one of my wheels every time I used my pump. Well worth the ten or so dollars.
CAAD10 Di2
PostPosted: Mon Sep 17, 2012 10:18 pm
fantastic. I saw they have them at Colorado Cyclist now. Worth the few bucks like you said.
PostPosted: Mon Sep 17, 2012 11:12 pm
Happens on occasion unless the core is properly screwed in. Once it is screwed properly in place it tends not to unscrew inadvertently.
Considering getting a Hirame pump head though, to use with my disc. Kinda tired of using the Zipp crackpipe which is a real PITA.
12 Canyon Aeroad CF 9.0 ETE
12 Canyon Ultimate AL
11 Cervélo P2
PostPosted: Tue Sep 18, 2012 10:40 am
Yes I agree the new pump head is better with the pressure release valve, although I still hold my valve extenders with one hand whilst unscrewing the pump head out of habit. One downside is that the pressure release head is a teenie bit longer and doesn't hold the hose as tightly when you clip the head into the base for storage - but that's a minor gripe compared to unscrewing the valves
CAAD9 | CAAD10
PostPosted: Wed Sep 19, 2012 4:35 pm
Dear Mr Lezyne ... How about you send me a free one of these thingys to go on my recently purchased Travel Floor Drive? And how about you send all your customers one?
And another one Mr Lezyne ... Why would anyone actually need an 'Air Bleed System' valve? With a proper valve head you just pull it off and the air is released.
Talk about overdesign.
PostPosted: Wed Sep 19, 2012 9:28 pm
...or just unscrew pump from hose before hose from valve and your pressure will be released sans the ABS button...? (I'm talking hand/mini pumps here)
PostPosted: Wed Sep 19, 2012 10:46 pm
You still have the pressure build up in the hose. The release valve works really well. Only a minimal amount of air is lost unlike my track pump which noisily loses a couple of psi when the head is removed from the valve.
PostPosted: Thu Sep 20, 2012 10:05 pm
What's a tried and true lubricant for the assembly that turns when the pump is attached and detached (while the pump head remains fixed within this assembly)?
Saura mon coeur que mon cul poise.
adapted from Rabelais
PostPosted: Fri Sep 21, 2012 2:17 am
If you don't like it, why did you buy it?
I like the lezyne system, not pump blowing off the valve at 100psi once the washer gets worn.
PostPosted: Sat Sep 22, 2012 8:34 am
I bought a Lazyne pump last winter and pretty pleased by it including this ABS release system.
My only complain is that sometimes the top of the cap would unscrew by itself when inflating tires... :?
ciclismo-espresso.com
PostPosted: Fri Oct 05, 2012 5:12 pm
Lezyne USA answered the question about lubrication in my post above. Taking off the chuck on the alloy floor pump exposes a 2mm allen. Loosen it, freeing a collar and exposing an o-ring. Clean up any dirt. Lubricate with Tri-Flow or similar, and reattach the collar , then the chuck. I tried this, and it works.
I didn't ask Lezyne about tightening the chuck, but using two pairs of pliers seems to work for this.
PostPosted: Sat Oct 06, 2012 7:29 am
The ABS system is great, no more pressure when you are trying to unscrew the head from the valve. Before that i have used some locktite on my valve cores in order not to be unscrewed, but now you dont need that.
The best think about the ABS and the threaded chuck is that the pump lives forever, no o-rings to fail, under high pressures and everyday use...
My Builds so far... C50,EPS Erik Zabel, C59 Di2.
PostPosted: Sat Oct 06, 2012 3:52 pm
Caveat: There is an o-ring in the outermost part of the chuck (Presta) which can become dislocated if the pump head is pulled off the valve at an angle after it has been unscrewed, so what you are saying is not 100% precise.
11 Cervélo P2
Users browsing this forum: Dalai, konky and 11 guests
There are no new unread posts for this topic. HP minipumps: lezyne , topeak or...
quattrings
15
861
Wed Dec 26, 2012 11:20 pm
jz4nyc View the latest post
There are no new unread posts for this topic. Lezyne Micro Floor Drive - HP Version
Valbrona
Sat Jul 14, 2012 3:30 pm
sungod View the latest post
There are no new unread posts for this topic. Attachment(s) All I Want is a Pump That Works ...
Valbrona
35
2468
Mon Aug 27, 2012 9:33 am
mrfish View the latest post
There are no new unread posts for this topic. Lightest shock pump?
in MTB
Jakomait
Thu Oct 18, 2012 11:20 am
TheRookie View the latest post
There are no new unread posts for this topic. Attachment(s) hand pump after a flat
project3
43
2219
Mon Mar 25, 2013 12:44 am
project3 View the latest post
It is currently Wed May 22, 2013 7:47 am
