Post new topic Reply to topic  [ 23 posts ]
Go to page 1, 2  Next
PostPosted: Tue Jul 24, 2012 10:42 pm
There's a similar post out here referring to the weight of a frame. I'm speaking about the wheels. Would 200gr savings in wheels make a noticeable difference?
Scott Spark LTD 8.40kg
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
PostPosted: Tue Jul 24, 2012 10:44 pm
Not really. You ride mtb right? I made a ~350-400g saving from dt swiss to handbuilt wheels and i could tell a small difference when stoping and accelerating.
2013 rocky mountain vertex 29er
­Twitter
www.cyclingtrainingnuts.blogspot.ca
PostPosted: Tue Jul 24, 2012 10:59 pm
depends where less weight will be (in rims or in hubs)
http://kavitec.blogspot.com/
click this! http://www.youtube.com/watch?v=jqfFdCWAH5I&list=UUEtgd6K9EDGmoSE2YYipQgQ&index=20
PostPosted: Tue Jul 24, 2012 11:29 pm
Hubs and spokes
Giant NRS (Retired)
PostPosted: Wed Jul 25, 2012 9:48 am
I dont know about you guys but I've noticed huge diferences going from heavy to light wheels. Its obviously more important then any other part of the bike because you have translational and rotational inertias involved. 300gr on the frame might not make much of a difference but on wheels sure thing! Add the aerodynamics factor in there and wheels are the most important component on the bike
Canyon Ultimate SLX 2013 + DA9070 + Red Quarq + Corima Aero+ MCC (Ordered! 6.0kg)
Canyon AeroRoad + DA9000 + Lightning Power2Max + MCU's (6.5kg)
Cervelo P4 + G3 Powertap (7.78kg)
Cervelo SLC + SRAM Red 2013 + Red Quarq (6.8kg)
PostPosted: Wed Jul 25, 2012 1:24 pm
In order for me to save 200gr on a wheelset I will have to spend $1262usd! :roll: Is it still worth it??
Giant NRS (Retired)
PostPosted: Wed Jul 25, 2012 2:05 pm
I guess 'worth it' will depend on your perspective. If you are competing at a high level then the small advantage could make all the difference and you might end up with a better result. If you are just riding then probably not, unless of course you want them and can afford them, then I think it would be worth it!
FWIW I just got a new road bike, but went from racing wheels to training wheels adding about 400g and there is a definite difference while accelerating and climbing. But I also have much heavier tyres on my training wheels, I think the total weight difference is nearly 700g as I went from Bontrager Race X Lights with Ultremo ZX's to handbuilt tough as nails training wheels with heavy duty hardshell tyres at nearly 400g a piece!
PostPosted: Wed Jul 25, 2012 2:24 pm
200gr from the rims make a really noticeable difference IME.
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
PostPosted: Wed Jul 25, 2012 3:29 pm
I was riding r sys Mavic clinchers and Topolino clinchers .I got a handuilt set of clinchers they now weigh 1172grms . My whole bike feels much lighter and quicker.
PostPosted: Wed Jul 25, 2012 4:05 pm
Every gram counts.
Cumulative gains (or in this case, cumulative losses).
Exp001
PostPosted: Wed Jul 25, 2012 4:30 pm
For my Shimano bike I have a pair of Dura Ace C35 and a pair of AX/Tune wheels. The RRP is similar but there is a 500g difference in weight. The AX wheels are a work of art but truth is I hardly ever use them.
When it comes to wheels smoothness, stiffness and durability are the benefits that count. If you are buying your main set of wheels spend the money on smoothness, stiffness and durabily over weight.
I wouldn't give up my AX wheels for anything but they are a second set for those rare mountain climbing days. Or when I just want to lift my WW bike and marvel over it's low weight. Sad hey.
PostPosted: Wed Jul 25, 2012 8:01 pm
lighter rim andspokes Ok.
Hubs: more important performance
we had a test on 7min climb, tempo ride, around 8%grade avg. wheelset 1. =1010g tubular, wheelset 2.=1680g clinchers.
power was almost same. NO difference in climbing time from point Start to point Finish.
but it was tempo ride; no quick accelerations in hill.
PostPosted: Wed Jul 25, 2012 9:23 pm
200 grams even on the tread is only 0.6% or less of total inertial load, 0.3% or less of the total gravitational load.
It's very hard to be consistent in two intervals to this precision. Mass from sweat loss, minor differences in wind, differences in rolling resistance from different lines taken, all confound the results.
So basically the answer to the original question is: theoretically it helps of course, but you'd never be able to notice faster times without careful analysis.
The wheels might well "feel" different, however. One might associate one or the other with feeling "fast".
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Wed Jul 25, 2012 9:51 pm
Wheels that spin well and/or are stiff will feel light more than light wheels will feel light.
PostPosted: Thu Jul 26, 2012 2:38 am
See Zinn's article on this topic in Velo news at their web site. Very informative and not all that clear about the benefits in all instances.
KAC
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
Users browsing this forum: Maximilian, mentok, russianbear and 9 guests
There are no new unread posts for this topic. Which wheels will make me faster?
bruno2000
13
1381
Sat Aug 04, 2012 11:02 am
g_doraz View the latest post
There are no new unread posts for this topic. Realistic Weight Savings on Cables
mattyb95
28
1477
Fri Dec 14, 2012 12:30 am
ferrarista View the latest post
There are no new unread posts for this topic. Attachment(s) Paging engineers --- ankling engery savings?
elviento
7
697
Fri Jan 18, 2013 10:01 am
wassertreter View the latest post
There are no new unread posts for this topic. Free weight savings on cable housing
Brandonnie
24
2159
Sun May 26, 2013 5:58 am
lechat View the latest post
There are no new unread posts for this topic. Bad enough to want to make you buy through your LBS again...
agent86
19
1357
Thu Jul 26, 2012 9:10 pm
It is currently Tue Jun 18, 2013 9:23 am
