Post new topic Reply to topic  [ 7 posts ]
PostPosted: Fri Jul 20, 2012 12:17 am
Do you all think my pedal is safe to use? i still can cleat on! what is the function of the metal plate?
Thanks
PostPosted: Fri Jul 20, 2012 4:51 am
Hard to say, the pic is pretty dark. Is the plate just dented at the side or detached from the body? If its just dented, I would say it's not a biggie. If the plate is detaching, I would worry that the plate would come off completely eventually and block the mechanism so that you can't unclip.
The plate itself is just providing a stable (and durable, hence metal) platform that your cleat "stands" on.
PostPosted: Fri Jul 20, 2012 9:42 am
It's the wear plate. If you can clip in, the pedal is fine to use. You may notice a bit of play in your cleats and the pedals may not feel as solid as before.
If you plan on tapping it back into position, make sure you line up the metal to fit into the grooves exactly. I had to chuck my last pair of Keo Blades because I wasn't careful and bent it so I couldn't clip in. IMO it's the Keo Blades only weakness, Look should have designed the plate like the DA 7900 pedals, with the wear plate attached to the pedal body with screws:
Much more repairable, but I guess heavier.
CAAD10 Di2
PostPosted: Fri Jul 20, 2012 1:44 pm
Won't Look replace that?
PostPosted: Fri Jul 20, 2012 2:55 pm
It was crashed. Why would LOOK replace it?
PostPosted: Fri Jul 20, 2012 3:56 pm
The same happened to me and the pedal is fine. The metal plate was bent and was making an irritating noise while pedaling so I had to "compress" it with pliers. Try to do the same and if possible fit the border of the plate back into the groove in the pedal body.
PostPosted: Fri Jul 20, 2012 7:50 pm
get some new pedals cheapskate - hell... its an excuse to bike bit shop... what are you waiting for?
Wiliers: Cento Uno; Cento SLR; Imperiale, Zero 7 (all Super Record 11sp naturally)
Users browsing this forum: Google Adsense [Bot] and 14 guests
There are no new unread posts for this topic. Is this seatpost un-safe?
mattyb95
20
1564
Tue Dec 11, 2012 10:15 am
theremery View the latest post
There are no new unread posts for this topic. Attachment(s) replacement Ti bolt safe here?
Bianchi10
10
500
Sun Nov 04, 2012 6:21 am
OrPe View the latest post
There are no new unread posts for this topic. is my bike safe to ride?
davidalone
Wed Jun 06, 2012 9:01 am
xuelan View the latest post
There are no new unread posts for this topic. Carbon bars safe?
in Cyclocross / Touring
Leonel
10
656
Mon Apr 22, 2013 1:56 pm
ms6073 View the latest post
There are no new unread posts for this topic. Pedal Force QS3-ISP
grahamcrackers
Thu Jun 14, 2012 2:10 am
WillT View the latest post
It is currently Tue May 21, 2013 10:55 am
LOOK pedals, plates & cleats - buy cheap LOOK pedals online
