It is currently Mon Jan 22, 2018 2:02 am
Post new topic  Reply to topic  [ 15 posts ]
 Post subject: Garmin acting funky...
PostPosted: Wed May 16, 2012 7:19 am
I don't typically do hill repeats, but today I decided to. First time, 480ft/148m. Accurate, since it was 0.7mi/1.12 km. Average elevation gain was close to 8%, but spiked to 12-15% once or twice.
Okay, I zoom down the hill to ride back up.
On the second time, the Garmin Edge 500 is displaying -1% to 3% grade, and an elevation increase of 170ft/52m in 0.7mi/1.12km.
Yikes, well, that's odd and not the same. My times were off from each other by less than 30 seconds comparing the two climbs, so it wasn't like my tempo was tricking the computer.
Later in the ride, I was cruising along at a fair speed, considering basketball sized potholes all over the place, and the accompanying gravel... Normally about 18-19mph, and this is pretty accurate, being in my 48x17. I had to check my gearing, because my garmin was saying I was going 11-13mph/ 17-20kph. Grrr...
Could it have been satellite/environmental issues? The ride was occurring 30 minutes after a decent day's rain, but since December 2009 (when I got the Garmin 500), I've never seen such wonky data...
Ugh. Any clues?
http://www.wvcycling.wordpress.com/
PostPosted: Wed May 16, 2012 4:13 pm
First, I'd check to make sure that you have the latest firmware for your garmin. If not, see if an update fixes it. Sometimes I've had goofy data show up on my edge in-the-moment, but the info shows up slightly differently when I download it into connect. My experiences have been with heart rate issues, mostly, but I don't see why that couldn't happen with speed too?? :noidea:
If I don't run the speed/cadence sensor and you are just using the GPS to determine your speed, then from what I've read on the garmin forums, it's possible that environmental issues like cloud cover or precipitation might affect your data.
If you are still getting batsh1t data points, then check over on the garmin forums (https://forums.garmin.com/forumdisplay.php?f=20) for some fixes. Some of the resourceful folks over there have come up with several ways to "fix" wacky data points in the .tcx files.
Good luck and I hope you find a fix!
-efwd
PostPosted: Wed May 16, 2012 4:21 pm
I think regardless of the speed/cadence sensor the unit always take the speed from the satellite. At least that was the case with 705, I am not so sure if 500 is any different.
Planet-X Nanolight HM - 5.63kg
PostPosted: Wed May 16, 2012 7:31 pm
If your Garmin is acting funky you obviously need to , " Take it to the bridge , good god get down "
Could not resist :) sorry .
PostPosted: Wed May 16, 2012 8:13 pm
I blame Vaughters
PostPosted: Thu May 17, 2012 2:43 am
I think I found my problem - Water.
New PC7 style mount exposes the bottom side to water flung up by the front tire. This clogged the little "beep" speaker hole. I'd like to blame this as the culprit, but I'm also taking your guys' considerations!
(Totally JV's fault. I blame the turtleneck sweaters too.)
Oh, totally forgot; here's the link to a recent example: http://app.strava.com/activities/869886 ... eated=true
PostPosted: Thu May 17, 2012 3:46 am
altitude, and gradient based on altitude diference, are always inacurate. I would be extremely surprised if, after repeating the same hill climbing twice, you get the same results, that wouldbe astonishing, it's extremely normal to have wrong data related to altitude stuff. This happens in my garmin 500, on polar, etc, etc... always. altitude sensor are very sensible to air pressure, and are very unreliable.
Happy Trails !!!
PostPosted: Thu May 17, 2012 5:00 am
Not true for the 500, mine works on rollers warming up for crits.
Bike Pure
PostPosted: Thu May 17, 2012 5:04 am
Oh, totally forgot; here's the link to a recent example: http://app.strava.com/activities/869886 ... eated=true" onclick="window.open(this.href);return false;
The 500 gets it's elevation reading by sensing the air pressure and that "speaker hole" is for the barometric altimeter, I believe. Uncover it and your elevation should be correct.
I'm not sure about the speed though. Do you have a speed sensor on there? Maybe the magnet was just far enough away that it was missing it every once in a while?
PostPosted: Thu May 17, 2012 5:27 am
Yup, when it rains the elevation data is almost useless. This is pretty well known I think.
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
Strava: Wayward Cyclist
PostPosted: Thu May 17, 2012 7:34 am
Being static or without a locked gps singal locked yeah, I am talking about normal road riding. The ideal would be for one to correct the other all the time, but I doubt that the garmins are that smart.
PostPosted: Thu May 17, 2012 2:48 pm
Nope, the 500 will use the speed/cadence sensor for speed/distance if it is connected instead of GPS. The 305/705 used GPS until the signal quality dropped like you said, however.
OP, is your wheel size set to Auto? I hear that can cause problems as well.
PostPosted: Thu May 17, 2012 11:55 pm
I'll have to check - Thanks for the suggestion!
PostPosted: Sat May 19, 2012 10:29 am
No. If there is a speed sensor present, it uses the speed sensor.
Bike Pure
PostPosted: Sun May 20, 2012 4:42 am
ON the 800 and pressumably the 500, if you set the wheel size to auto it will use GPS data in comparison to wheel speed to determine wheel size and then use the speed/cadence for speed from then on.
There are no new unread posts for this topic. Garmin Edge 520
in Wanted
vladoo
Tue Dec 26, 2017 12:39 pm
vladoo View the latest post
in Wanted
vladoo
Tue Dec 26, 2017 12:23 pm
There are no new unread posts for this topic. HRM Options with Garmin Egde 520
in Training
StevenH72
Tue Sep 26, 2017 8:46 am
savechief View the latest post
There are no new unread posts for this topic. Deda SuperZero and Garmin
jbrandt
21
3090
Mon Jun 19, 2017 3:59 pm
5 8 5 View the latest post
There are no new unread posts for this topic. Garmin 510 and sram etap
Jowwy
Sat Jun 24, 2017 5:34 pm
oldnslow2 View the latest post
Users browsing this forum: No registered users and 6 guests
