Post new topic Reply to topic  [ 7 posts ]
PostPosted: Mon Apr 23, 2012 1:15 am
My Physical Therapist recommended I wear compression shorts under my cycling shorts because of a quad strain. Unfortunately, my team is sponsored by Giordana and they don't have compression in their shorts. Has anyone here worn compression under their cycling shorts? Is it uncomfortable? Does it help? Any thoughts would be appreciated. Thanks!!
PostPosted: Mon Apr 23, 2012 3:05 am
They are fine as long as they don't bind in between your legs.
Try them out and report back. Thanks.
PostPosted: Mon Apr 23, 2012 4:26 am
I just chaffed reading this.....how about cutting the leg off a compression short and just wrapping your quad? Would negate the issue.
PostPosted: Mon Apr 23, 2012 11:36 am
Location: At the bottom of the barrel & starting to dig
Why not buy the skins c400 cycling shorts and get the best of both worlds. Super comfortable insert as well
PostPosted: Mon Apr 23, 2012 12:15 pm
These are your answer -
Available world wide via amazon or wiggle. They are easier to size via Wiggle.
http://www.wiggle.co.uk/compressport-forquad-thigh-guard/
I have some, excellent. They work.
PostPosted: Tue Apr 24, 2012 7:20 pm
I'm kind of surprised a PT wasn't familiar with the compression sleeves. I'll bet he/she just spoke in terms of shorts because she/he didn't know that wearing shorts under bicycle shorts would be an issue (probably a lot of non-cyclists or casual cyclists just assume one wears underwear).
Anywy, there's a million compression sleeves out there. Either chose one your self, or ask your PT for a recommendation. Again, I'm assuming the PT recommended shorts without knowing why the sleeve would be the way to go.
PostPosted: Tue Apr 24, 2012 8:21 pm
Thanks guys!! I did not know quad compression sleeves existed. I will order the 2xu quad compression sleeves.
Users browsing this forum: No registered users and 8 guests
There are no new unread posts for this topic. Attachment(s) Assos, Exte Ondo Shorts and Bib Shorts
mnmasotto
Fri May 03, 2013 5:23 am
mnmasotto View the latest post
There are no new unread posts for this topic. How snug should shorts fit?
ScottGoBlue
11
1614
Wed May 23, 2012 4:34 am
kac View the latest post
There are no new unread posts for this topic. Looking for new road shorts any suggestions!
G6612
10
658
Thu Nov 22, 2012 10:42 pm
bman11 View the latest post
There are no new unread posts for this topic. Attachment(s) Rapha 3/4 Shorts - size 32
EpicRide
Thu May 09, 2013 8:33 am
EpicRide View the latest post
This topic is locked, you cannot edit posts or make further replies. What long bib shorts for 0-10ÂșC?
in Training
Velofreak
Wed Nov 28, 2012 9:58 pm
Stolichnaya View the latest post
It is currently Sun May 19, 2013 7:15 am
