Post new topic Reply to topic  [ 14 posts ]
PostPosted: Sat Apr 14, 2012 9:13 pm
This may sound like a stupid question, but I just want to check before I replace the tires.
Are tubular tires supposed to hold air as long as clinchers? I recently bought a pair of 808s that both had glued tires. The guy had them pumped at 140psi, but within a matter of 4-5 days they had lost all their air. I tried airing them up last night, and they had probably lost 10-20psi since then.
Is there anyway to fix the problem, without replacing them? The tires appear almost brand new.
PostPosted: Sat Apr 14, 2012 9:24 pm
If it is a quality tubular, with latex inner tube, this is normal. You pump them to the required pressure before you go riding.
my plastic bikes, 29ers & stable of old steel
PostPosted: Sat Apr 14, 2012 9:36 pm
One has a zipp tangente the other has a Vredestein fortezza pro. Not sure if either of those have latex tubes.
PostPosted: Sat Apr 14, 2012 9:48 pm
Yes, both latex tubes. Don't worry about it.
PostPosted: Sat Apr 14, 2012 10:01 pm
Thanks!
PostPosted: Sun Apr 15, 2012 12:15 am
Although, you sill may wish to check the quality of the seal of the valve extenders...
PostPosted: Sun Apr 15, 2012 4:30 pm
Hi,
I have a question too.
Do I have to put air all time? or leave as is and when I need put air and go ride?
Because I have a disc and will use only once a while and have to off 2 month.
This case, do I have to put air least once in sometime? or just leave it and put air right before I need to use?
thank you guys.
PostPosted: Sun Apr 15, 2012 6:20 pm
I don't see a reason why you should put air in consistently. If you are, I imagine you might wear the tube out just slightly more than letting it sit months at a time.
PostPosted: Sun Apr 15, 2012 9:23 pm
geoff is right
i loose about 10-15 psi in 2 days, when i inflate them at around 110psi
the lower the pressure the slower leakage.
PostPosted: Mon Apr 16, 2012 5:37 am
These are my first tubulars, and they already came pre-installed...
Is there a way to check the valve extender seal without detaching the tire?
PostPosted: Fri Apr 20, 2012 4:41 am
If you are not losing much pressure in the space of a couple of hours I wouldn't even bother.
PostPosted: Sun Apr 22, 2012 1:27 am
Unfortunately, no. If you can't get them to pressure easily, the problem must be the extenders. That is not very likely down to the Vittoria tires.
PostPosted: Wed May 16, 2012 3:29 am
I get the same problem with my Zipp 808. At first I thought it was the valve extender, but found that it's actually the tangente tyre. I have conti GP4000s on my other tub wheels and they don't suffer from the 'leak'.
PostPosted: Wed May 16, 2012 3:31 am
Conti tubulars don't use latex tubes.
Users browsing this forum: No registered users and 11 guests
There are no new unread posts for this topic. Different tire pressure for different wheelsets?
G6612
Mon Aug 27, 2012 4:02 pm
G6612 View the latest post
There are no new unread posts for this topic. Bike Tire Pressure System, really?
Ghastly
Mon Jan 07, 2013 6:55 pm
Pharmstrong View the latest post
There are no new unread posts for this topic. Which 25mm tubular tire?
MikeMiranda
32
2251
Thu Jun 21, 2012 11:04 pm
fdegrove View the latest post
There are no new unread posts for this topic. Schwalbe Ultremo HT 25 mm tubular tire. NEW.
LouisN
Sat Feb 16, 2013 11:59 pm
LouisN View the latest post
There are no new unread posts for this topic. Tubular 29er tire choice
in MTB
drider85
7
802
Fri May 10, 2013 1:02 am
WheelBuilderOrg View the latest post
It is currently Sun May 19, 2013 10:27 am
