setback seatpost 27.2
cymans
by cymans
Can anyone recommend a large setback seatpost with 2 bolt micro adjust. dosn't have to be carbon. i'm also running a shim so have size options. running a 27.2 at the moment.
setback between 25-35mm would be good.
cheers,
Cyman.
Rick
by Rick
Thomson Masterpiece in 27.2 setback is only 158 gms, and they are rock-solid. But they only have 16mm setback.
25mm is about ideal for my bike, but I can make the Thomson work with the saddle slid back on the rails.
HillRPete
by HillRPete
Ritchey has offerings with 20 and 25mm setback, but I haven't finished my build yet, so I can't weigh in.
djm
by djm
Canyon's VCLS seatpost in 27.2 is great.. very comfortable, and you have adjustable setback all the way to 30 mm.
eric
by eric
FSA, Deda, 3t and Zipp make them, among others.
mjduct
by mjduct
I have a 3T Dorico LTD that I'd sell you pretty reasonably, It came with my Cervelo R5 frameset, I needed a straight one as the 25mm setback goofed up my position, it might have 200 miles on it before my fitter pulled it off. PM me if you are interested
elSid
by elSid
As mentioned, Ritchey has several posts w/ 25mm setback. I tried the Superlogic, but I couldn't get it to stop ticking when I'd go over a bump. Torqued to spec, used carbon paste, used round railed saddle, but I couldn't lose the sound.
http://www.excelsports.com/main.asp?pag ... 1&minor=19
I ended up using a Velo Orange Grand Cru, which has about 33mm setback. I don't have a scale, but it feels about the same in my hand as my Thomson masterpiece from another bike. It is well made and doesn't tick.
http://store.velo-orange.com/index.php/ ... tback.html
I've not tried it, but FSA makes a long setback post in 27.2.
cymans
by cymans
thanks for all the replys.
Any idea where i can get the Canyon's VCLS seatpost and how much.
cheers,
cyman
ok, just found it on there wesite.
