Post new topic Reply to topic  [ 71 posts ]
Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Apr 19, 2012 6:34 am
nathanong87 wrote:
griptape?! isnt' that like sandpaper....ouch!
...yeah...
Took a while but it's softened up a lot now. at first it was ok for short periods but now it's fine. Only problem is i like riding with my hands on the tops and i'm getting holes in all my gloves. No chance of slipping off though
PostPosted: Thu Apr 19, 2012 7:34 am
ultyguy wrote:
Or you can go 'pro' style and copy what Sky were doing at the Tour of Beijing ITT w/ road bikes...
whats going on there? I can't really see or tell what the bulges on the bar are.
PostPosted: Thu Apr 19, 2012 8:40 am
Sorry, small pic, if you click on it to expand you can see that they have rolled kind of 'doughnuts' on the handle bars so that the forearms wouldn't bounce side to side too much. I can't remember if the UCI had a view on this or not tho.
The interesting thing about that ITT tho was that it was run on road bikes and it produced exactly the same results as an ITT run on TT bikes would have. :smartass:
1 Tony Martin (Ger) HTC - Highroad 0:13:34
2 David Millar (GBr) Team Garmin - Cervelo 0:00:17
3 Alex Dowsett (GBr) Sky Procycling 0:00:24
4 Christopher Froome (GBr) Sky Procycling 0:00:26
5 Stephen Cummings (GBr) Sky Procycling 0:00:35
6 Lars Boom (Ned) Rabobank Cycling Team 0:00:36
PostPosted: Thu Apr 19, 2012 8:58 am
I'm normally a "grab the missing aerobars" guy but last night I tried the spartacus approach and must say it felt very good!!! Didn't lose any noticeable control or the ability to put power down if needed. Think it may become my new go to position.
PostPosted: Sat Apr 28, 2012 9:55 pm
With the Zipp contour SL bars the position is fairly comfortable. Your forearms do get a bit beat up, I did a 20k TT that way and while I was riding it was fine but once I stopped my arms were not happy.
I also feel like it is a very stable position, there is plenty of friction for my to make corrections to my path and most bumps are ok. It is also a good change of pace on longer rides. Like someone earlier said, it is a great way to stretch your back and give your hands a rest from holding onto the bars.
My Lynskey R420 with Chorus 11
NEW Developments! If you are interested in a Weight Weenies kit please respond to the thread. I want to make the order happen before long.
PostPosted: Sat Apr 28, 2012 11:47 pm
What I would like to see is a hybrid of these bars. Top section of the aero basebar and drops of their drop bar. I think this would make a killer aero drop bar. What I like is that you could use a "COMPUTER MOUNT" to fill in the holes and actually mount your power meter on the end but maybe have it stick out just a bit more than normal so you could ride on the top of the bars and have something to hold on too. I actually posted this in another forum and someone from felt did reply.
What I asked for was a computer mount to fill in the holes for the aero extensions for road riding, shortie aerobars for ITU racing and some slightly longer extensions for grand fondo riders. The ITU and longer distance riders could add armrests if wanted but I think the tops are flat enough that you would not have too.
I was told that this was a 1%er request as only a very small portion of people would want something like this but if 3T can offer the Zefiro and it is in their line, I do not see why someone else could not improve on it and offer what I am suggesting.
A very cool bar that is aero drop bar that is technically OK to use in UCI, ITU and normal riding.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Tue May 01, 2012 8:55 pm
what about this position, just noticed it on wiggle and i've never seen anyone using it before.
looks quite compact, I might give it a try
PostPosted: Tue May 01, 2012 10:47 pm
Looks like he is descending though. Unsure how that position will work when pedaling.
PostPosted: Wed May 02, 2012 12:10 am
I do that with my hands on top of the bars. Works for me
WW Velocipedist Gargantuan
PostPosted: Wed May 02, 2012 1:35 am
Ditto. Top of bars, not underneath (better control that way). I use that whilst descending.
Exp001
PostPosted: Wed May 02, 2012 3:37 am
+2 on top of bars close to stem with elbows dropped and chin/face just far enough behind the stem that if I do hit a bump I do not lose a tooth or two.
BIG DADDY B FLOW
PostPosted: Wed May 02, 2012 6:03 pm
JamieL wrote:
...yeah...
You could try some hockey friction tape instead. That should be much easier on your arms and gloves. ex. http://www.icewarehouse.com/descpage.html?pcode=FT
PostPosted: Wed May 02, 2012 6:32 pm
nibali did this underhand descending technique during his attempted escaped during LBL. that was the first time i've seen it
PostPosted: Fri May 11, 2012 10:04 am
Exp001
PostPosted: Fri May 11, 2012 8:29 pm
I've seen Sanchez seen descending like this in the TdF, except that he properly grabbed the handlebars from below, and put his chest on top of the bars. Looked very very tucked, and he could stay in the saddle, as opposed to sitting on the top tube.
Bikes: Raceur, Beateur
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Users browsing this forum: thencameyou and 14 guests
This topic is locked, you cannot edit posts or make further replies. Aero road frames
Martin.F
7
1119
Thu Aug 30, 2012 12:57 pm
wassertreter View the latest post
There are no new unread posts for this topic. Lightweight aero road bars
mattjevans
14
673
Thu Apr 18, 2013 8:55 pm
woz9683 View the latest post
There are no new unread posts for this topic. Aero Wheel & Disc Help Needed for TT and Road Racing
ProudDaddy
16
877
Thu Dec 20, 2012 9:25 pm
gilesharrison View the latest post
There are no new unread posts for this topic. Aero or Nero (not aero) ? (New bike frame)
stang1
29
1824
Thu Apr 18, 2013 6:36 pm
Kayrehn View the latest post
There are no new unread posts for this topic. "Aero" Road Helmets that are not TT helmets?
prendrefeu
40
7331
Sat Nov 10, 2012 10:55 am
gregalfa View the latest post
It is currently Thu Jun 20, 2013 7:44 am
