Post new topic Reply to topic  [ 25 posts ]
Go to page 1, 2  Next
PostPosted: Mon Mar 05, 2012 2:59 pm
Hi all,
New Kask k-10 arrived with a crack in the impact absorbing foam material, photo attached. Approx 4cm long and located just above the right ear when wearing. It appears deeper than a surface crack and opens slightly when finger pressure is applied to the area.
The seller assures me that all is fine, that it happens in manufacture and that all of the other helmets he has have the same crack. I'm concerned that it's had a whack in transport and that it will be a weak point in a crash.
Anybody heard of or experienced this before? Any advice or comment will be gratefully received.
PostPosted: Mon Mar 05, 2012 3:16 pm
not to fearmonger, but...
that's what my helmets have looked like after a crash.
If in doubt, you need to show it to a local distributor either of Kask, or at minimum someone from another reputable high-end helmet company.
PostPosted: Mon Mar 05, 2012 3:20 pm
All may be fine, but even "cosmetic defects" are still DEFECTS and the seller should replace the helmet.
PostPosted: Mon Mar 05, 2012 4:06 pm
Get a refund. I might say get an exchange, but if the seller is dishonest, I wouldn't want to do business with them. If you can't get a refund, then just don't use it. Who is the seller (retailer/reputable online website, ebay, private individual)?
That is, unless Kask tells you this is normal.
PostPosted: Mon Mar 05, 2012 5:49 pm
It sounds like he's trying to bullsh%t you, send it back get a refund, go somewhere else. Who makes products with cracks in them and then try to pass them off as ok.
PostPosted: Mon Mar 05, 2012 7:09 pm
@HammerTime2 - It was bought through ebay, a +2000 score and 100% feedback seller. His communication has been good and has given detailed enough explanations. Item is otherwise perfect with all tags.
I've been sent some photos of the other helmets the dealer has in stock, in a variety of colours, all showing the same crack in exactly the same place. So it hasn't been damaged in transit and the dealer is being honest enough.
However, I have sent an enquiry directly to Kask to get their view on this and whether it will affect the helmet's performance in a crash.
PostPosted: Mon Mar 05, 2012 7:21 pm
Is it possible that the ebay dealer bought a bad batch cheaply - perhaps factory rejects out the back door? Or maybe they are counterfeit and of defective manufacture?
PostPosted: Mon Mar 05, 2012 7:30 pm
Helmets are the one thing I refuse to mess around with regarding anything that might feel or look "off". It's your head but if it were me that is the last place I would take even a .01% chance on something not being up to snuff.
Personally I would get a refund and buy another somewhere else.
Looks like I made a new 90 Proof friend
PostPosted: Mon Mar 05, 2012 10:05 pm
I wouldn't risk it! :shock:
PostPosted: Tue Mar 06, 2012 12:57 pm
FECKED HELMET!
i like people... i just can't stand assholes
PostPosted: Tue Mar 06, 2012 1:10 pm
100% feedback may not be so meaningful in some cases.
I started a "fake Pinarello" thread over on RBR with exhibit 1 being sold on the 'bay by a seller with 100%. He made a slight alteration to the text, tho still misleading, after being called on it.
dangerous curves ahead
PostPosted: Wed Mar 07, 2012 3:23 pm
So he has a batch of helmets that all have the same defect. Maybe that's why he is selling them on ebay.
I still see the known defective easton EC90 cranksets on sale at ebay.
Just get a return/refund. You don't need a good excuse, you just aren't happy.
If they balk, submit to ebay problem resolution immediately. There is no way it can be denied that it is a defect, and now you have evidence from the seller that it was defective when he sold it to you.
PostPosted: Fri Mar 09, 2012 7:04 am
Here's you answer. e-Bay is the dumping ground for companies(individuals) that are able to get factory seconds and then sell them off. Some sellers will tell you up-front they are seconds and some won't.
A cracked helmet...............there is no way in **LL I would strap that thing on.
CRC.com still has (3) models of the KASK all on sale for $142.80 U.S. dollars
And I'm thinkin they won't have cracks.
PostPosted: Fri Mar 09, 2012 7:07 am
This seller needs to be reported thru the e-Bay system. He sould NOT be selling damaged helmets.
e-Bay would not allow this if they knew.
PostPosted: Fri Mar 09, 2012 8:10 am
My Kask K10 which I bought from a reputable LBS has a similar crack. I never noticed it until reading this thread. It seems pretty minor, practically need to look at it under a microscope to see it though.
I've been riding with it for months and it seems to do an fine job of holding my brains in thus far :lol:
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 8 guests
There are no new unread posts for this topic. Kask helmet Bambino
endorfin
Sun Mar 24, 2013 12:46 pm
endorfin View the latest post
There are no new unread posts for this topic. new Kask Mojito Helmets
Robitaille20
Thu Dec 06, 2012 3:32 pm
Robitaille20 View the latest post
There are no new unread posts for this topic. Kask helmet sizing
ichobi
Tue Jan 01, 2013 3:50 am
tonytourist View the latest post
There are no new unread posts for this topic. Kask Mojito & Limar Ultralight
vala
Fri Mar 08, 2013 3:44 pm
dvincere View the latest post
There are no new unread posts for this topic. Kask Mojito + Oakley Radarlock
yongkun
9
1324
Sat Sep 29, 2012 8:52 am
Monkeyboy3333 View the latest post
It is currently Sat May 18, 2013 9:36 am
