Show us your sub-6kg builds
caad10dotcom
by caad10dotcom
Vallinotti wrote:Here is the mine :D
Frame - AX-Lightness Vial EVO 52cm
Fork - THM Scapula CT
Headset - AX-Lightness stock
Wheels - Meilenstein Obermayer Tubular
Tires - Continental Competition 22mm
Skewers - Lightweight
Crankset - THM Clavicula M3 110mm / SRM
Chain - KMC X11SL-DLC-Black
Chainrings - Praxis Works 52/36
Front derailleur - Sram Red 22
Rear derailleur - Sram Red 22
Chain Catcher - Carbonice
Shifters - Sram Red 22
Cassette - Sram Red 22
Brakes - THM Fibula
Stem - AX-Lightness Rigid 120mm
Handlebar - MCFK without stickers
Handlebar plugs - Carbonice
Handlebar tape - Deda Elementi cork
Seatpost - AX-Lightness stock
Seatpost - AX-Lightness Daedalus 27.2x350mm
Saddle - AX-Lightness Leaf
Pedals - Time Xpresso 15
Brake housing system - AICAN Bungarus housing and cables
Shift housing system - Power Cordz Swift Cable System
Bottle cage - Mighty
That is absolutely sick!
by 573
Only just <6kg at 5,990g
2013 Supersix Evo Red; size 54.
It's not high-modulous carbon, is on alloy clinchers and has no really exotic parts so I was pleased to get it under 6kg, even if it's only just under.
RyanH
by RyanH
Here's the R5ca in its fat configuration @ 5.8kg:
Full build list is in my sig but some things to highlight that changed or are not obvious from the picture:
Super Record 11s Shift Group
Super Record Skeleton Brakes (roughly +120g)
SRAM Red 11-25 Cassette
Praxis 52/36 Chainrings (IIRC +70g)
Zipp 404s with Zipp Skewers (roughly +600g over the RZRs)
Strava
reedplayer
by reedplayer
@573: i am quite shure, that your evo is himod! btw very nice bike!
ardi69gain
by ardi69gain
5.77kg for now...
Sent from my SM-A710F using Tapatalk
tmr5555
by tmr5555
That blue Berk pops!
jefftillack
by jefftillack
ardi69gain what brand is that? Looks awesome..
ardi69gain
by ardi69gain
jefftillack wrote:ardi69gain what brand is that? Looks awesome..
Its Velobuild VB-R-077 frame. Weight 843gr for size 49.
dudemanppl
by dudemanppl
maverick_1
by maverick_1
5880 grams as seen.
Sacke
by Sacke
Lightweight Urgestalt. About 5.3kg. A friends bike, I just took the picture.
KCookie
by KCookie
Sacke wrote:Lightweight Urgestalt. About 5.3kg. A friends bike, I just took the picture.
Apart from my Urgestalt this is the only one I've seen on here, and it's 200g lighter. Any chance of a built list with weights so I see where I could loose some weight in the future. !!
Sacke
by Sacke
Apart from the stuff that is visible, it has an Extralite stem, Schmolke bars, Fibula brakes, Tune Komm-Vor saddle, Aerolite pedals etc.
I can ask for a more detailed parts list some day and check the weight. :)
ride1970
by ride1970
Scott Addict SL. 5.8kg with pedals
AUOC1OC6
Location: Global Citizen but mostly in Australia and Asia
by AUOC1OC6
Here's my recent build: AX Vial Evo D in Size 54 @ 4.585 kg
Spreadsheet with weights (in grams):
Frame: Ax Lightness Vial Evo 675g
Fork: THM Scapula CT 310g (300mm uncut steerer+expander) 284g (cut steerer without expander 11g)
hanger: Ax Lightness 11g
Headset: Ax Lightness 55g with CeramicSpeed headset bearing plus Ahead cap and expander screw 6g
seatpost clamp: Ax Lightness 6g
Seatpost: Schmolke TLO 300mm 85g
Seat: Mcfk 77g
Stem: Ax Lightness Rigid 110mm 79g
Bar: Schmolke TLO Oversize 420mm 31.8mm 144g
Bartape: Deda perforated 23g
bottle cages and hardware: Tune 18g
Shift Cables: Alligator iLink 74g packing weight
Brake Cables: Aican Bungarus 86g packing weight
Brakes: THM fibula + brake shoes 145g brake pads:30g
Front derailleur SRAM Red with Carbonice chain catcher 76g
Rear derailleur: SRAM Red with CeramicSpeed pulley wheels and Fibre Lyte rear mech plate 145g
Crankset: THM Clavicula SE 302g
Bottom Bracket: CeramicSpeed BB30 40g
Chainrings: Fibre Lyte 53T- 59g & 39T- 30g
Chainring bolts: Carbon Ti X Fix Road kit 8g
Chain: KCNC 11 speed 205g
Shifters: SRAM Red 293g
Cassette: Recon Raceday 96g with POP Lock ring 4g
Wheels: Ax Lightness P38 Tubulars 430g front & 540g rear
hubs: Extralite CyberFront SP (48g claimed) & CyerRear SP (129g claimed)
Spokes: DT Swiss Aerolite SP 274g (claimed)
Rims: AX lightness Stream 38mm (claimed 290g each)
Inner Tubes: N/A
Skewers: Tune Skyline 18g
Tires: Tufo Elite Jet 167g each
Pedals: Time Xpresso 15 142g
Polar/garmin/computer mounts: N/A
Tape/glue: 20g
AUOC1OC6
AX Lightness Vial Evo D http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138599
Corima Puma
Giant MCR 2 (retired)
Trek Y Glide Deluxe MTB
