It is currently Mon Feb 20, 2017 5:12 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Nov 20, 2013 7:13 pm
Hi
I am looking to use my Garmin 800 on the home trainer and realized the only way to do this was to use the Garmin GSC 10 speed and cadence sensor.
I have attached this and although my garmin seems to recognize the sensors attached I don't seem to be able to view the speed?
Any help much appreciated!
PostPosted: Wed Nov 20, 2013 7:43 pm
Maybe you have speed set to gps? And not sensor
PostPosted: Wed Nov 20, 2013 10:05 pm
the only way to correct this is to completely turn off the GPS sensor in the head unit. From my experience, if the GPS reads 0, but the speed sensor is moving, it throws the system off, and just reads 0 speed. Once you have the head unit read speed from only the sensor, then the issue goes away. Just make sure you turn GPS on for your next ride.
I own a lot of Treks
PostPosted: Wed Nov 20, 2013 10:45 pm
When you watch the LED on the unit, does it blink as the wheel magnet passes the arm?
PostPosted: Wed Nov 20, 2013 10:47 pm
It's not selectable. If a speed sensor is paired, it prefers that for speed over GPS.
PostPosted: Fri Nov 22, 2013 5:46 pm
I've had a ton of problems with their speed sensor. First thing is to make sure your wheel magnet is close enough to the sensor but not to close as when fame and wheels flex it will hit it. If that doesn't work then reset the sensor by holding down the button on the sensor for 5 or so seconds. The button should blink alternating green and red and the wheel magnet and cadence sensor go by, this will let you know if they are in range as well.
There are no new unread posts for this topic. Stage PM + Garmin Speed Sensor
addictR1
9
696
Sat May 21, 2016 7:15 pm
addictR1 View the latest post
There are no new unread posts for this topic. SOLD - Garmin Edge 500 (used) and GSC10 speed/cadence (new)
Johnny Rad
Sun Feb 12, 2017 9:37 pm
Johnny Rad View the latest post
There are no new unread posts for this topic. Diabetics & CGMS... where do you put your sensor?
in Training
superdx
Mon Oct 31, 2016 12:50 pm
Nefarious86 View the latest post
There are no new unread posts for this topic. Seeking advice on which ANT+ sensor suite to get
WannabeWeenie
Fri May 13, 2016 4:08 pm
uraqt View the latest post
There are no new unread posts for this topic. Brake squeal slowing down from higher speed, but works fine with slower speed.
stockae92
Mon Jun 27, 2016 5:40 pm
Calnago View the latest post
Users browsing this forum: No registered users and 8 guests
