It is currently Mon Jan 22, 2018 3:31 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Tue Sep 03, 2013 8:30 pm
I have just purchased 510 and done two rides on this and discovered a major flaw with the recording of speed. The speed seems to be inconsistent and dropping at regular intervals almost consistently over the whole ride. I have updated to the latest firmware already 2.70, and cannot figure for the life of me after searching google why this would be happening, my edge 200 was faultless and even the iphone app was more consistent with speed recording
I have also set GPS to GLONAS.
Take a look at these....
A friends edge 510 speed recording, normal for everyone....
Now my speed recording thats affecting alot of data recording, Garmin upload said 18.3 miles ridden strava uploaded it as 20.4miles, garmin average speed 14.9mph and strava 16.1mph average, calories was also incorrect!!
and zoomed in on a segment....
can anyone explain whats going on here and what could I do to sort this? I cant find any other posts with the same problem.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
PostPosted: Wed Sep 04, 2013 10:27 am
Does it do this on anything else on garmin connect or any other prog as well as strava?
Livetracking and your phone data connection?
Did you charge it properly first?
Official cafe stop tester
PostPosted: Wed Sep 04, 2013 4:57 pm
http://www.scarletfire.co.uk/2013/06/ho ... on-strava/
Go to the 20% boost example :lol:
All digital cheating aside though, I vaguely remember hearing of someone using an Ant+ speed sensor and it causing troubles like that. Garmin said they thought there was a bug and it was having trouble deciding between GPS and the sensor's speed. Are you using a speed sensor or just relying on GPS speed?
What are you using to upload it to Strava? Straight from the Garmin on Strava's site? I have seen Strava make a mess of files uploaded through various different programs.
Maybe try calling Garmin? They've always been good on the phone with my customers in North America.
PostPosted: Wed Sep 04, 2013 10:31 pm
Appears it must be a but when auto stop is set to custom speed......dont try it...
PostPosted: Thu Sep 05, 2013 4:31 am
I hope you're climbing a hill with a ride that short and slow :smartass:
The New: BH http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=117760
PostPosted: Tue Sep 24, 2013 5:43 pm
I've experienced the same issue. I don't think it depends on the auto stop, because mine is not set at custom speed.
I used:
GPS+Glonass
No speed/Cadence sensor
1s recording
SRM
HR
Strava upload straight from the 510's .fit file
PostPosted: Sat Sep 28, 2013 10:31 pm
I've no idea of the how the twin positioning system's work on the 510.
But in general, if data is gathered from two sources, then the joining of them can result in glitches like this. Of course it should not be eliminated by the firmware.
PostPosted: Fri Nov 22, 2013 7:07 pm
That happened to me a few moths back. Ended being a bad speed/cadence sensor. First try to reset the sensor and make sure the magnet is place close enough. On rides with the speed jumping around I would just disconnect it and use GPS. Try emailing Garmin for a new cadence sensor, it will take a long time with their excuses and make you do lots of stuff before they send you a new one, but it will happen.
PostPosted: Sun Nov 24, 2013 2:51 am
Pivens, I hope that is not your ECG...
There are no new unread posts for this topic. SRM speed sensor not connecting to Garmin 500
TomColnago
11
284
Sat Jan 06, 2018 7:47 pm
TomColnago View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
766
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
There are no new unread posts for this topic. Mixing 10 speed sram and 11 speed 105
jowen
Mon Mar 06, 2017 8:40 am
kulivontot View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1561
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
Users browsing this forum: micky, wingguy, zulu695 and 11 guests
