It is currently Mon Jun 26, 2017 1:16 pm
Post new topic  Reply to topic  [ 41 posts ]  Go to page 1 2 3 Next
PostPosted: Sun Feb 12, 2012 12:06 am
Hi Folks:
After the disapointment of my cracked Supersix frame, ive decided to rebuild my CAAD9 for this season.... will post soon... sram blk red, sisl, Ive sold my 303's and am in the market for a new set of clinchers....
I want clinchers because for me tubulars arent an option for my club rides and sportives. I want a wheel I can use for climbing and training without worrying about durability... :shock:
im considering:
1) Reynolds thirty two's
2) DT Swiss RRC's 32mm
3) Zipp 101
4) Hed Ardennes FR
Whats the WW reccomendations?
Caad9 BBQ Durace7800 build
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=82445#p721875
PostPosted: Sun Feb 12, 2012 1:54 am
How much do you weigh? Riding style? I'd go for a hand built option. Maybe a Stan's build or A23 rims on some DT190s would be pretty solid.
PostPosted: Sun Feb 12, 2012 2:05 am
Reynolds 32 are best here, Zipp 101 are good but not worth its price, also my fav clinchers Dura-Ace 7900 C24, can get ~$1000
they are surprisingly aero: http://www.rouesartisanales.com/wp-cont ... -table.jpg
and amazing build quality: http://www.cyclingnews.com/features/a-l ... el-factory
PostPosted: Sun Feb 12, 2012 4:00 am
Any interest in Reynolds 46'S?
PostPosted: Sun Feb 12, 2012 6:13 am
Shimano wheels are either absolutely amazing or pure crap. Many of my friends have had theirs warrantied multiple times. They had no hassle dealing with Shimano during the warranty process and spoke very highly of it. MY shimano wheels have been absolutely astounding. Zero issues, completely solid, very smooth. In the 3 years I've ridden mine I've only had to true them once - and that was because I hit a massive pothole so hard that I nearly went over the bars (even then it was a very light true).
Outside of that, I can speak very highly of Fulcrum racing zeros/ones.
PostPosted: Sun Feb 12, 2012 6:32 am
Aluminum clinchers begin and end with 101s.
Fulcrum 1s or 0s come in second.
Nothing beats a Campy hub, but Zipp is close (although, it will require more maintenance). The downer for Fulcrum is spokes that are $$$$. I didn't think that I'd ever sell my Fulcrum 1s. But I did as soon as I rode 101s (CAAD9, Red, SI SLs).
PostPosted: Sun Feb 12, 2012 8:35 am
I hear a lot of good and bad reviews for the 101s, my own experience with 303s put me off because for everyday riding the rear hubs needed servicing regularly.
I'm 6'3 and weigh between 92-95kg.
PostPosted: Sun Feb 12, 2012 10:41 am
Hi Matt,
I'm 6'4" / 82kg and had built up a pair of HED Ardennes rims into my 'ultimate, do-all wheelset'. I'd spent the previous few seasons on Reynolds and had tried using their carbon clinchers (DV46c) as my everyday wheelset, but found that the rims simply aren't up to it. As soon as you need to do one descent in poor weather, or in a crowd of not-so-good descenders (sportives), you will need a new rim. Fortunately, I lived in the prairies at the time, but even still, the experiment only lasted a few months before I needed to buy a proper everyday wheelset.
The one issue with the HED wheels is that the hubs are crap. Gorgeous bearings to start with, but worse then the Zipps for durability.
Having been impressed by the DT Swiss 240s hubs on my Reynolds wheels, I built my HED's with these and I've been very happy. The only caution that I'd provide is that I chose to build them 20/24 to keep the weight down (1440g as memory serves), and as a rather aggressive rider (I often 'skip' my rear wheel cornering in races), I do bring the rear wheel out occasionally, but it trues up easy enough and holds true well... until the next crazy attack in a corner!
(Un)Fortunately, I'm back into a sponsorship situation now and looking at selling my Ardennes, as I can't use them for a season and I need to move around A LOT. If you want to go new, I'd recommend a build similar to this (even using another trusted hub if you have the funds), with a consideration for 28h rear if you're particularly hard on equipment - 20h front should be fine.
I'm very confident in saying that clinchers do not begin and end with the 101's... these are lighter (~85g less each rim), stronger & more durable. In my opinion, that makes them better too.
PostPosted: Sun Feb 12, 2012 10:10 pm
Curious...how can you claim the HED/ DT is a "stronger" wheel when you can bring it out of true while attacking a corner?
For what it's worth, I raced 101s last season, but am currently on HED C2 clincher built with White hubs and Aerolite spokes. 20/24.
PostPosted: Mon Feb 13, 2012 12:14 am
I think it's stronger because it has more spokes (some of which are heavier) , it's laced two-cross on both sides and the rim doesn't lag or wander when sprinting. 20 spokes with a radial DS didn't work particularly well for me in a much stiffer/stronger 808 rear build and during my rather extended test ride of the 101's, I found the same thing - up-hill attacks especially would result in brake rub.
I'm not claiming the 24-spoke, 2-cross rear is indestructible in any way, but in my experience/opinion, it's stronger then the 20-spoke, radial DS of the 101.
PostPosted: Tue Jul 09, 2013 11:47 pm
I'm currently in need of a new set of wheels as the current mavic sle might be going to a new home. Where I live it's not very flat and has a decent climb here and there which is more where I prefer to ride.
I'm not sure which route to take, either the aero wheels again or some light climbing wheels.
My list consists of
Mavic cosmic SLR aero
Mavic R-sys climbing
Bontrager aeolus 3 D3 mixed
What are peeps recommendations?
Thanks
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
PostPosted: Wed Jul 10, 2013 12:04 am
Assuming tubs, why not zipp 404 or 303 having shopped around a bit...
Reasonable weight & should be just on your price line.
That's what I'd go with anyway..
PostPosted: Wed Jul 10, 2013 7:50 am
What about 202's? They have tested well and give something of a compromise between deep section aero and climbing wheel?
PostPosted: Wed Jul 10, 2013 9:25 am
forgot to say need to be 11spd ready.
PostPosted: Wed Jul 10, 2013 2:00 pm
With your white and green 5 Series, only one choice: Bontrager Aeolus 3 D3 :D !!!
When you say mixed, you're thinking 5 rear ?
The more I look at them, the more I want...
Louis :)
There are no new unread posts for this topic. Carbon Climbing Tubulars under 1500$?
in Everything wheels
Pan
Thu Jun 01, 2017 3:21 pm
shineplus View the latest post
There are no new unread posts for this topic. 2016 Dura Ace 9000 SRM new bat\cal $1500
itsacarr
Tue May 30, 2017 4:16 pm
itsacarr View the latest post
There are no new unread posts for this topic. Feeler: 2016 S-Works Tarmac, 54cm frameset (800 miles) $2000
CrimsonKarter21
Tue Apr 04, 2017 6:10 pm
CrimsonKarter21 View the latest post
There are no new unread posts for this topic. S-Works Tarmac Frameset, 54cm, LightBlue/White/MatteBlack (price drop $2000)
CrimsonKarter21
Mon Jun 19, 2017 4:20 am
There are no new unread posts for this topic. Fuji SL 1.1 Disc or Cannondale Synapse Hi Mod Disc or any other Disc Frame under 2000 dollars
vanmatthew
Fri Nov 18, 2016 9:34 pm
mpulsiv View the latest post
Users browsing this forum: racingcondor, raggi and 4 guests
